Will I Need An LT4 KM?
Old Apr 27, 2007 | 06:28 AM
turnin20s's Avatar
When I got my tune Ion desensitized (SP) my knock sensor, but will I still need to get the LT4 KM? Or should I just wait and see if I pull any knock retard?
Thanks in advance
Old Apr 27, 2007 | 09:36 AM
OBE1 95Z28's Avatar
I would wait and see.
Old Apr 27, 2007 | 11:02 AM
jsetzer's Avatar
LT4 KM is a waste, do it in the tune. Yes you will have noise with a forged piston. And you will have piston slap when its cold.
Old Apr 27, 2007 | 11:23 AM
2000GTP's Avatar
I would wait and get the car scanned. Only way of knowing for sure.
Old Apr 27, 2007 | 03:54 PM
turnin20s's Avatar
Whats a good scan tool to invest in? I was going to get the LT1 scanmaster, but I'm running out of money and my machining turned out to be twice as much as I was planning on but I know I could use a scan tool
Let me know
Old Apr 27, 2007 | 05:03 PM
Get the free download from:
TTS DataMaster:
http://www.ttspowersystems.com/ (20 free uses)
FreeScan:
http://www.andywhittaker.com/
Then get a cable, specifically for the type of connector on your laptop, and the 16-pin ALDL connector on your 95:
http://www.akmcables.com/
Then read this:
http://members.aol.com/InjuneerZZ/ScanMast.htm
The LT4 knock module **MAY** be useful. It is a filter circuit that include filtering specifically tuned to eliminate the noise signature of the Crane Gold roller rockers used in the LT4 engine. It differs from "desensitizing". The filter keeps **SOME** extraneous noises from reaching the PCM's knock retard system. Desensitizing either reduces the level of all of the signals reaching the PCM (resistor circuit), or limits the PCM's response to all the signals that do reach it (PCM tuning). A subtle, but important difference in function that escapes some people.
Old Apr 27, 2007 | 05:59 PM
turnin20s's Avatar
TTS DataMaster:
FreeScan:
Then read this:
Thanks, all I need now is a laptop I think a buddy of mine has one and I can download some stuff for his car and we'll be even then. I appreciate all of the links that you provided, now for some reading
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
