New water pump now car won't start
Old Apr 28, 2007 | 04:48 PM
AXEMAN's Avatar
OK so I will apologize now for the long post. I had a leak from my water pump so I got a new one and changed it. While I had the pump off I went ahead and pulled the opti so it could air dry. I started to open it but did not. Since I had never replaced the hoses I went ahead and got the goodyear high miler set and changed them too. I put everything back together and the car would not start. I figured that I had missed the index putting the opti back on so I broke it all back down to see. This time, before putting it all back together I reset the opti (which I think was right anyway) and it hit as soon as I touched the key. So thinking that was it I put it all back together and now it will not start again. When I say won't start I mean it won't turn over. The starter just keeps trying. When I started it earlier the only things missing were the water pump (plus all associated hoses), and the cold air intake and the belt. I am at a loss. PLEASE HELP ME. Thanks.
Old Apr 28, 2007 | 08:58 PM
93transam1234's Avatar
Double check the wire to the opti is plugged in good at both ends.
Try to unplug the / take off the cold air intake and see if it will start.
Old Apr 29, 2007 | 12:25 AM
RedsTA's Avatar
Id double check all your wires. When we did my waterpump, we mixed a couple wires and it didnt start the first time, so we had to switch a couple wires we had mixed.
Old Apr 29, 2007 | 08:40 AM
mn96ss's Avatar
yeah, id make sure all wires are in the right order cuz I just did a new water pump and MSD cap and rotor yesterday and it fired right up. Its usually stupid little stuff that messes you up. Good luck.
Old Apr 29, 2007 | 07:45 PM
AXEMAN's Avatar
Update: The car was flooded from me having the left side on a jackstand and not the right. Thanks for your responses.
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
cristian1311
Nov 23, 2014 02:22 PM
