2.00/1.56 valves..... Question?
Old Apr 23, 2007 | 07:48 PM
hotrod18_69's Avatar
I've got a set of ferrea valves 2.00/1.56 valves laying around and wondering if it would be worth having them install in my stock heads? (561's) Heads are bone stock no porting at all, soo i'm not sure it if would help or hurt me.. I'll be running the CC306 as well on a 355 with around 11.6-1 compression.
I just don't have the cash for LE2's yet and trying to get the most out of what i have at the moment..
What do you guys think?
Old Apr 23, 2007 | 11:18 PM
seawolf06's Avatar
You're going to build a 355 and just put stock heads back on? You're going to be missing out on a lot with that cam and stock heads. You might see a little gain from the bigger valves, but it'll be nothing compared to the gain you'd see from even just the LE1 budget heads. I think Lloyd keeps stock size valves even on some LE2 heads, but I may be wrong. You can get great flow numbers with the stock valves. Keep saving some money or get the heads ported on credit and get whomever to do a valve job and install the valves.
I spent a little more getting ported heads and Manley 2/1.56 valves installed but I'm happy that I did it. Now I don't have to take the heads off again for a long time.
Old Apr 23, 2007 | 11:30 PM
rasputin's Avatar
im interested in this question as well. while one might not see a noticeable gain, it would not hurt the motor right? i mean, if they heads are off and porting is too much money, and new valves are needed, should this be done?
Old Apr 24, 2007 | 09:35 AM
BUBBA's Avatar
Explain to me how a larger valve can increase flow without machining for the valves. Thank you very much for your support.
Old Apr 24, 2007 | 10:36 AM
Z-RATED94's Avatar
Exactly, you need to at least cough up the cash for some pocket porting and a nice valve job.
Old Apr 24, 2007 | 12:00 PM
seawolf06's Avatar
Yeah, just putting in larger valves won't give you any gain. At the very least you need a valve job, but even then you're spending more money for very little gain.
Old Apr 24, 2007 | 02:50 PM
rasputin's Avatar
what does "machining for valves" entail? without porting, what would one do to gain power from bigger valves?
Old Apr 24, 2007 | 10:31 PM
seawolf06's Avatar
It means getting a 3 or 5 angle valve job or even a full-radius job. I don't think you're going to see much if any gain from larger valves without porting. I'd put my money into a great port job than I would aftermarket valves.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
