motor tries to stall when stopping
Old Apr 23, 2007 | 10:38 PM
witemanfromhil's Avatar
I have a 96 Caddy with the LT1, sometimes the engine almost stalls out when I come to a stop, if I shift it to nuetral it clears out, not real sure whats going on, I checked all my connections and vacumes and found nothing out of the ordinary. any ideas!!!
Old Apr 24, 2007 | 12:18 AM
ibringdarukus's Avatar
yea 8 times out of 10 its the opti spark.
Old Apr 24, 2007 | 03:50 PM
The idle speed is controlled by the IAC motor. The PCM holds the idle higher until it verifies that the vehicle has actually stopped (VSS signal = 0). There is a table of "follower" values that controls idle speed on coast down. Appears you may have a problem with the IAC motor, if it is unable to keep the engine from stalling. Do you have access to a scanner or scan software that would allow you to observe how the PCM is attempting to control the idle using the IAC motor?
Old Apr 24, 2007 | 06:42 PM
Z28LT1_Just_Nasty's Avatar
Had the same problems when my opti went. Another vote for opti.
transam_388
Mar 15, 2015 11:53 AM
edman
Jan 25, 2015 02:41 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Perry93TransAm
Aug 20, 2002 11:23 PM
