Oil leak/AFR Heads and LT4 Valve covers
Old Apr 20, 2007 | 05:59 PM
BMAN'S SCZ's Avatar
Hey guys I have an oil leak coming from the back of both valve covers. I tried replacing the gaskets, but no luck. They are Afr 190 heads and Lt4 composite valve covers. I thought I seen a member here post that he had to turn the stud shorter to squash the gasket more but not sure and a search didn't pull anything. Is anyone else having any problems with this setup? Thanks for any info.....John
Old Apr 20, 2007 | 07:24 PM
joeSS97's Avatar
Yes,you need to cut the bolts a little,so they clamp down more on the valve covers...Otherwise they bottom out in the hole.
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
