Passenger side header
Old Apr 28, 2007 | 02:15 PM
Mortify's Avatar
Installing passenger side header is a bitch, it seems that the collector is getting the control arm... how can we get this to fit in WITHOUT lifting the motor?
Old Apr 28, 2007 | 02:19 PM
2000GTP's Avatar
What kind of header is it, a long tube? When trying to get my Pacesetter long tube in thru the passenger side, I found myself spending quite awhile playing with the angles to get it just right to snake in in there. Be careful and don't force it because if you have a coated header, you'll scratch it up real quick. If that doesn't work, then yes, you may have to end up unbolting a motor mount and raising the motor a tad.
Old Apr 28, 2007 | 02:25 PM
Mortify's Avatar
Its hooker LTs, i don't have an engine hoist to raise it a "tad" !!!
Old Apr 28, 2007 | 03:54 PM
97formula808's Avatar
you can lift the engine a tad w/ a jack and a piece of wood under the oil pan
Old Apr 28, 2007 | 05:21 PM
lethal93ta's Avatar
I had to get my car up off the ground way up, I have 24 inch jack stands all the way up, with it that high I could get the angle from the bottom.
Old Apr 28, 2007 | 08:28 PM
KillWhitey's Avatar
Get the car high enough and it will snake in from the bottom
alex5366
Feb 17, 2015 10:43 PM
Jul 4, 2005 05:00 PM
blue89iroc
Jul 26, 2002 04:56 PM
