beehive valve springs
Old Apr 27, 2007 | 12:08 AM
lt1street's Avatar
Hey guys,
Going to be installing so comp beehive valve srings, couple of question. Im running a cc305 with 1.6 roller rockers and was wounder what would be better as far as springs, the 26915-16 or the 26918-16? And what is the differents between the two?I noticsed that comp say to use to different retainers too, with 915 you use the 787-16 and with the 918 you use the 774-16 what is the differents between the ?
Thanxs, Grant
Old Apr 27, 2007 | 01:47 AM
seawolf06's Avatar
I think comp may have changed some of their beehive spring part numbers.
Get the 918's with 10 degree +.050" locks and retainers and the comp locators as well.
Can't remember the exact differences, but I think the 918's have higher spring rates.
Old Apr 27, 2007 | 08:38 AM
Z-RATED94's Avatar
What he said. You won't be disappointed. 918's rule.
Old Apr 27, 2007 | 03:38 PM
lt1street's Avatar
Hey,
What is meant when the a +.50 valve lock ?
Old Apr 28, 2007 | 02:25 AM
seawolf06's Avatar
+.050" lock
It raises the installed height by .05".
Old May 1, 2007 | 07:27 AM
SStrokerAce's Avatar
On stock valves you almost have to run the +.050" locks.
Bret
R@mpage
Apr 20, 2015 10:02 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
