bleeder screws backing out- help
Old Apr 24, 2007 | 07:19 PM
dueno's Avatar
My bleed screws on my radiator hoses have the heads almost ruined to the point that a screwdriver will barely turn them. Also, they have backed out of their holes after I drove the car, spraying coolant all over my brand new optispark. It appears there was something beneath the heads of the screws to prevent them from backing out, but I can't figure out what I should use to replace it. Should I just use thread locker on the threads, or do I need something else?
Old Apr 26, 2007 | 12:50 AM
dueno's Avatar
ttt
Old Apr 26, 2007 | 04:49 AM
Guest47904's Avatar
Guest
Put a jam nut on them. If the heads are screwed up, replace them.
Old Apr 26, 2007 | 02:30 PM
Dave1980's Avatar
when I worked in a shop If there was a loose bolt or joint, we would sometimes use superglue on the threads. It will tighten things up. (only would be a temporary fix)
Why in the world would the bleeder screws keep backing out? Were they overtightened or stripped?
They do sell a hose replacement for that area.
Old Apr 26, 2007 | 05:50 PM
dueno's Avatar
no, the threads are fine, but I think something was originally underneath the heads of the screws to keep them from backing out, like a rubber gasket or something? If someone could check their bleeder screws for me and tell me what it is, that would be great.
Old Apr 26, 2007 | 06:55 PM
There is nothing under the head. Because of the way the screw works, the head is not even supposed to go all the way down.
Old Apr 26, 2007 | 07:20 PM
Boosted_Z28's Avatar
Why not just replace them? Part #10070107 They are about $5.00 each from GM
Old Apr 26, 2007 | 08:31 PM
Dave1980's Avatar
Now that he mentions that, I can take mine all the way out on both of them.
Old Apr 26, 2007 | 09:09 PM
Dave89IROC's Avatar
huh?
Old Apr 27, 2007 | 12:19 AM
Heatmaker's Avatar
Advanced Member
There's a removable grade thread locker for things like that... It's white... and most people use them on head bolts... but I think if you ahve to do all that... your bleeder screw probably needs to be replaced. I mean the entire assembly not just the little piece you unscrew to get the air out. just replace it.
Old Apr 27, 2007 | 09:48 AM
foggedz's Avatar
Put some thread locker on them. I think they have a small amout of thread locker on them from the factory. If you have used them alot the factory thread locker may have just worn off.
Old Apr 27, 2007 | 04:06 PM
Dave1980's Avatar
Originally Posted by Dave89IROC
huh?
What is there not to understand? I can take out each bleeder screw if i wanted to, as in put both in my hand. I was stating that they are removable.
grgguy
17
Feb 23, 2015 07:57 PM
owen66
Nov 30, 2014 04:21 PM
mspennyhughes
Nov 28, 2014 03:22 PM
squarehead
Nov 21, 2014 08:02 PM
Lions3
Aug 30, 2002 01:03 PM
