fuel injection flush worth it??
Old Apr 28, 2007 | 08:33 PM
arklie's Avatar
Is the professional flush from a mechanic worth the $150 or is the $10 additive that you can buy at the parts store good enough? Opinions? Thanks in advance.
Old Apr 28, 2007 | 09:04 PM
CSJTA's Avatar
If you are having injector probelms, it would be worth the pro flush.
For maintenance, I would just get the store bought stuff, I have had good luck with the Chevron, STP and BG brands, BG being the best.
Old Apr 28, 2007 | 10:15 PM
tnmotown's Avatar
I work at a chevy dealership and we use the BG products with the air/fuel induction service. Its not hard to do, just hooking it up to the schrader valve, unplug the fuel pump relay and run the system till its done. Our price is around $125 and it does work pretty well. But if you are on a budget the $10 store additive isnt bad either. If you are in the CA area i could hook a f-body owner up!
Old Apr 28, 2007 | 10:21 PM
johnny3986's Avatar
I have had great success with Sea Foam for maintenance. It won't burn up injectors and O'reilly's and Advanced carry it.
That $150 service is most likely the one that Jiffy Lube and Valvoline do for $49.99 and they off a 100% money back gurantee...even if you want your money back due to the smell that lingers for about 10-15min.
Look in to it, because the "advanced" fuel cleaning services are little more than a bottle in the gas tank, and then another bottle of a seperate cleaner, put in to a bottle, and then connected to a vacuum line. The vacuum line cleaner then (reportedly...never used it) picks up all the stuff in the combustion chamber, 02 sensors, and intake tract.
We sell the same stuff where I work at Speed Lube.
Old Apr 28, 2007 | 10:32 PM
HardcoreRM125's Avatar
FWIW, I had 8 injectors that were literally clogged solid with varnich. They wouldnt spray, drip, seep, nothing. Car sat from 96' when it was totaled to 03' when I bought it and restored it. My Dad's old boss got him some gallon container of some professional carb/injector cleaner. I took the O-Rings off, threw em in, and a few hours later, they all sprayed perfect. Havent had a problem since. The stuff was WHICKED though. It ate through my rubber gloves before I could even pull the first injector out. Being the genious I was, I figured since it didnt "burn" my skin it didnt matter anyways and just yanked them out with dissintegrating gloves on my hand, and the next 3 days skin was peeling off like when you get sunburn ... Definatly worked great though so I can personally say, injector cleaner DOES work if its concentrated.
Since then ive been running Lucas alot, I like the stuff.
Old Apr 29, 2007 | 12:44 PM
2000GTP's Avatar
Unless they are actually clogged, I would probably hold off and use the money elsewhere.
Old Apr 29, 2007 | 01:36 PM
seawolf06's Avatar
We run simple green through our injectors at work to clean them.
Old Apr 29, 2007 | 07:32 PM
itzkwik's Avatar
BG > you cannot beat that product,put it in on 1/4 tank drive around the block fill up th tank and let it do its magic, find a BG store and buy it there or have it shipped to you ,I believe its called 55k or something, costs about twenty bucks, tellin ya you'll thank me if you do it
Old Apr 29, 2007 | 08:01 PM
n2ceptor's Avatar
beltrunner
Apr 15, 2015 01:10 AM
Sauced
Mar 29, 2015 10:53 PM
Jubjub
Mar 19, 2015 10:23 AM
Brady
Jul 29, 2002 10:30 PM
Z-4-ME
Aug 13, 2001 10:35 PM
