how to install water pump seal
Old Apr 22, 2007 | 11:18 PM
race u 2's Avatar
I was just wondering if there is a seal installer to install the water pump drive shaft seal that is in the timming cover I tried to install one today with no luck it pushed the inner seal to the out side dose gm make a seal installer for this seal or what have you guys been useing to keep from folding the inner seal in
Old Apr 22, 2007 | 11:30 PM
JP95ZM6's Avatar
I believe there is a trick to make a tool for that from a highlighter pen body of the right OD. Might search for that, or just look around for one.
Old Apr 22, 2007 | 11:39 PM
I just slide the seal over a socket.
Old Apr 24, 2007 | 12:25 PM
don's Avatar
don
where did you get that seal? if not from the dealer what is the brand and part number?
Old Apr 24, 2007 | 01:43 PM
qboneus's Avatar
I just used the H2o pump coupler..It's the right size. it's easy to position your seal 'lips' orientation on properly.
My stealership didn't have one but napa carried a felpro set that has all seals\gaskets for the front timing cover.
Tal
Old Jul 11, 2007 | 08:48 AM
sabre81's Avatar
What size socket has worked for you?
Old Jul 11, 2007 | 10:27 AM
Socket barrel diameters vary by brand and I don't recall the exact size. I used a deep Craftsman socket that was barely larger than the surface of the drive gear the seal has to slip over. The seal was just snug on it.
The reason I used the socket was that it was already nice and smooth and would not harm the seal.
There is also this: http://www.impalasuperstore.com/nais...TOPIC_ID=30984 that was posted since this thread was started.
Old Jul 11, 2007 | 10:48 AM
don's Avatar
don
a socket did not work for me i ruined two seals that way. it feels like it went on good but i took it off to make sure and it was messed up
Old Jul 11, 2007 | 01:44 PM
sabre81's Avatar
did you grease or oil it?
Old Jul 11, 2007 | 01:51 PM
don's Avatar
don
yes. the problem was that it would come off the socket before it went on the shaft
Old Jul 11, 2007 | 01:57 PM
scottso's Avatar
This helped me tremendously - and I used his method.
http://www.impalasuperstore.com/nais...t,seal,install
But, even with this I messed up the first seal.
I think the socket I was using to seat the seal slipped on one of my strikes and mangled the outer seal. Of course I didn't know this until I was fully reassembled. Had to redo the entire project after getting it together and finding a leak.
The first time I used oil. The second time I greased it up.
Old Jul 11, 2007 | 03:12 PM
I did not use any lubricant.
Old May 27, 2008 | 12:35 PM
mdacton's Avatar
I have to put one of these on today....
any last minute tips?
I hate these seals.....I think everyone needs an electric pump.
Old May 27, 2008 | 12:36 PM
sabre81's Avatar
eh, i just used my finger with some oil and stretched it nice and easy until it slid on. That sounds so dirty. LOL
Old May 27, 2008 | 01:13 PM
All the tips are in the previous info. If you watch what you are doing, it's really pretty easy.
