Good FP.....no pulsing injectors
Old Apr 22, 2007 | 02:40 PM
30696bird's Avatar
I just did the VATS bypass because my security light was staying on and now my light is off but my injectors STILL won't ground. I took a test light and hooked it to the battery (+) while poking through both the injector wires (separately) just to make sure I did not get the wrong one. With the key off both wires are grounded and when you turn the key on they both go positive. If I try to start the car they both stay positive. I don't know what to try next...... Any idea anyone?
BTW, you can hear the FP when I turn the key and I have 45PSI with the key in the on position and while cranking. Thanks
Old Apr 22, 2007 | 05:20 PM
LT1_383's Avatar
The injectors might fire too quickly for your multimeter to read the pulse. Do you have a noid light you can use?
Old Apr 22, 2007 | 05:54 PM
30696bird's Avatar
No. I was actually using a test light. I sued it on my 91 300ZX when I put the engine in it and you can see the light, light up when they fires. I figured you could see it on a lt1 too. I guess I can go buy a noid light tomorrow.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
nophix
Nov 30, 2014 10:26 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
