optispark
Old Apr 27, 2007 | 03:19 PM
bigdawg6114's Avatar
optispark
My camaro water pump just started leaking. My opti works find, but i am wondering should i change it out anyway if its been wet from the water pump leakage.
They are pretty expensive so i would rather keep the old one, what should i do to be safe...
Old Apr 27, 2007 | 03:40 PM
transAMdriv3r's Avatar
just let it air dry out, ive washed my engine compartment down a few times and it never hurt anything, i just let it sit for a good day and it runs as good as before.
Old Apr 27, 2007 | 08:34 PM
sandman63's Avatar
Well my is water pump is leaking an my opti just crapped out on me, so i would.
Old Apr 27, 2007 | 08:40 PM
OBE1 95Z28's Avatar
If you're doing the labor yourself, the obvious answer when you're trying to save money is don't change it. Worst case is you'll have to change it later. If you're paying someone for the labor, it's about the same amount of labor to change the opti as it is to change the water pump (you have to pull the water pump to get the opti off). If the car has high mileage it might be wise to replace the opti.
Old Apr 28, 2007 | 11:15 AM
2000GTP's Avatar
Let it dry out, chances are it'll be okay.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
