cam
Old Apr 21, 2007 | 10:37 PM
snareman's Avatar
cam
can anybody explain the differences in these cams 304cc,305cc,306cc.tell me the specs and what ones I have to change stock componets with. thanks
Old Apr 22, 2007 | 04:13 AM
sssalah's Avatar
CC 304, 210/220 @ 0.05" lift, adv 266/276, lift 0.500/0.510, LSA 114
CC 305, 220/230 @ 0.05" lift, adv 276/290, lift 0.510/0.510, LSA 114
CC 306, 230/244 @ 0.05" lift, adv 290/307, lift 0.510/0.540, LSA 112
Valave lift is with 1.5 ratio rocker. Valve spring must be changed with any of these cams.
Old Apr 22, 2007 | 07:28 AM
snareman's Avatar
cam
so is there any advantage with the 305 over the 304? with the 305 I would need to buy everything seperate. with the 304 you get everything in the kit.306 looks like a big baller.
Old Apr 22, 2007 | 08:32 AM
er-z's Avatar
the cc305 and the cc503 are as big as you should on stock heads . the real
? is do you have to pass a smog ? bigger cam tend to make there power higher in the revs . and yes all the springs will need to be changed . i hate to be a ***** but try the search button . your ? has been asked many times .
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
