Miss fire?
Old Apr 22, 2007 | 08:58 PM
henryz28's Avatar
Miss fire?
My car has a miss fire at low rpms 1500 and down.When I first start the car it runs rich and some black smoke comes out the rear after a few revs the gas smell goes away,but under light throttle you can fill the car missing.Also If I am going down the road and floor it their is a delay befor it takes off.But at high rpms I don't fill a miss.I canged the cap and rotor and wires and plugs; but the it is doing the same thing.I have felt gas leaking out of the fule presure regulator.I am thinking its eather the regulator or the injectors.What do you guys think?Thanks
Old Apr 22, 2007 | 09:15 PM
bombebomb's Avatar
Did you change the plugs before or after? Make sure they are gapped correctly, if not it will miss at low rpms and do EXACTLY what your explaning, happend to me like a week ago lol.
Old Apr 23, 2007 | 06:18 PM
henryz28's Avatar
when I get the chance I am going to take the plugs out and check them.
Old Apr 23, 2007 | 06:32 PM
henryz28's Avatar
Would a bad coil cause the same thing to happen?
Old Apr 23, 2007 | 07:09 PM
wrenchin's Avatar
if you got fuel coming out of the vacuum port of the regulator you absolutely, positively, need a new regulator. when you pull more engine vacuum, like at an idle, you will suck more fuel into the intake through the regulator. not to mention your fuel pressure will prob be off.
Old Apr 23, 2007 | 07:34 PM
henryz28's Avatar
Ya it dosent happen all the time but some times I get a strog gas smell and when I put my hands on the regulator my had comes back full of gas. I am not shure where its leaking from but if it dose start it stops once I worm it up.
Old Apr 23, 2007 | 07:52 PM
henryz28's Avatar
What kind of regulator should I get stock or adjustable.Car is a 1996 z28 lt4 hot cam kit and full bolt on's.
Old Apr 25, 2007 | 11:20 PM
henryz28's Avatar
Ok I checked out the plugs and wires; they are all good.It seems to be geting worse I can't even spin the tires off the line;but it powers up a few seconds latter.
Old Apr 26, 2007 | 07:53 PM
henryz28's Avatar
Now that I think about it the car wasent missing untill the cam swap.And I diden't install the opti my budy did.Could he have installed it incorrectly.The car can't even burn rubber it was faster befor the cam.
Old Apr 26, 2007 | 08:08 PM
henryz28's Avatar
How would the car act if the opti was put in wrong.
KYWes
Jun 14, 2022 06:52 AM
techstar
Aug 6, 2015 11:20 AM
BMX Dad
Aug 3, 2015 09:15 AM
BMX Dad
Jul 27, 2015 02:39 PM
RUNMYTA
Jul 15, 2015 07:50 PM
