Canton valve covers
Old Apr 21, 2007 | 08:31 PM
96 SS 1424's Avatar
Canton valve covers
Does anyone with a 96 or 97 camaro SS run the Canton fabbed aluminum valve covers, want to make sure they will work with the SS ram air system.
Old Apr 22, 2007 | 01:36 PM
96 SS 1424's Avatar
ttt
Old Apr 24, 2007 | 08:52 AM
96 SS 1424's Avatar
anyone with an SS have these
Old Apr 24, 2007 | 11:40 AM
blown383's Avatar
The valve covers shouldn't interfere with the stock SS intake system. However you may run into a snag with the cover's not clearing the alternator.
-B
Old Apr 24, 2007 | 02:04 PM
The Engineer's Avatar
-B
I the Cantons are fabricated with a notch on the passenger's side cover to clear the alternator. Basically, they are made for an F-Body application, check-out the photo below.
WD
Old Apr 24, 2007 | 02:49 PM
blown383's Avatar
Originally Posted by The Engineer
I the Cantons are fabricated with notch on the passenger's side cover to clear the alternator. Basically, they are made for an F-Body application, check-out the photo below.
WD
That was the whole reason i bought them but I they are just not made correctly.
1) The cut out doesn't fit right and the power steering pump gets in the way.
I had to fabricate a spacer for the alternator and the alternator bracket to get it to function properly and rotated the outlet line for the power steering pump.
2) The tabs to locate the cover has to be bent so that it's seated properly
3) It doesn't clear the CC Pro Magnum rockers since they are wide...they needed to be ground down.
-B
P.S. Someone should tell Canton to reengineer these covers! A set of brand new $200 valve covers shouldn't require this much tweeking!! What sucks is if I sent these covers back it would cost me about $20-30 in shipping and a few weeks to get a new set in.
Old Apr 24, 2007 | 03:13 PM
jasonisdn's Avatar
lol damn man that sucks. you are the second one i have heard that had a issue with the cantons. the other guy said that the covers came without a oil fill hole in it. good luck with you car , btw i like that chorme effect on the alt and water pump, looks good
Old Apr 24, 2007 | 06:36 PM
Heatmaker's Avatar
Advanced Member
I just ordered a set of these... hope I don't have to adjust them too much.
Old Apr 24, 2007 | 09:04 PM
30AnvZ28's Avatar
****... mine are sitting here waiting for the motor to go back together... I hope I dont run into this.
Old Apr 25, 2007 | 10:23 AM
rickyzZ28's Avatar
I just got done putting a motor together and I had to grind the underside of the VC to clear the pro mags on the motor. I also had to make a spacer much like The Engineer did. Mine did not hit the power steering pump though, but I am suprised they did not. Terrible quality for a $200 set of valve covers. I could have just as easily put stock VCs on and clearanced them for free. I know people always say that Canton stands behind their product, but I do not have weeks to wait while they fix a problem that should have already been taken care of.
Old Apr 25, 2007 | 10:32 AM
blown383's Avatar
Did the stock length serpentine belt fit with the new spacer?
-B
Old Apr 25, 2007 | 10:39 AM
rickyzZ28's Avatar
Yes but it was a lillte loose, but I am also running an ATI damper that is smaller than stock. I will get the part number for the smaller ATI belt that fits perfectly for me when I get home.
Old Apr 25, 2007 | 10:40 AM
blown383's Avatar
Sweet! Im running the ATI damper myself.
-B
Old Apr 25, 2007 | 10:46 AM
rickyzZ28's Avatar
-B
I thought so, but didnt want to make an assumption.
Old Apr 25, 2007 | 07:34 PM
DZNUTTS's Avatar
that sucks. Was planning to get a set.
I would think Canton would be better than that.
