Car starts then dies...
Old Apr 21, 2007 | 07:41 AM
94_camm's Avatar
Ok just got my 383 finsished..now when i go to start it it turns on for like 2 seconds then shuts off...then i had someone hold the throttle open half way..now when that happens the car stays on.do you think i should turn the fuel pressure up?or is it something else??
Old Apr 21, 2007 | 07:52 AM
rich152's Avatar
There are a few things you should check. Start with vacuum leaks. And Check your IAC and reset it. Start with the little things first.
Old Apr 21, 2007 | 10:14 AM
'94 Bad A Z28's Avatar
Starts for 2 seconds and then dies, but will stay on with the throttle open... sounds like the car is sucking in air AFTER the MAF. Check for any misalignment/leaks after the MAF.
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
