Pulley won't go back on.
Old Apr 28, 2007 | 11:54 AM
350LT1's Avatar
Ok, I've searched but did not find what I was looking for.
Only found on how to remove the pulley.
I'm trying to put the harmonic balancer pulley back on, but it won't move. Is there a special technique or tool that is needed to put it back on?
Old Apr 28, 2007 | 12:31 PM
Did you remove only the pulley/damper, or the complete assembly, including the hub?
Old Apr 28, 2007 | 05:14 PM
seawolf06's Avatar
I used all thread and some nuts and washers. Using a piece of flat steel and pipe also helped.
Old Apr 29, 2007 | 03:55 AM
350LT1's Avatar
Ok, I may have used the wrong name for it, but its the pulley that is right next to the alternator.
I just removed the pulley. I used the Autozone loaner tool to get it off and it came off pretty easy. Now I was trying to use a rubber mallet to get it back on, but that wasn't working too well. It would slide on a little bit, but then it just wouldn't go any further.
Old Apr 29, 2007 | 06:03 AM
Dave89IROC's Avatar
um, the power steering pulley?
if yes, stop beating on it, you will destroy the pump, if you havent already
go back to AZ and get the P/S pulley installer
Old Apr 29, 2007 | 01:40 PM
seawolf06's Avatar
OK, yeh, that's the PS pump as mentioned. You're prolly gonna have a nice "supercharger" whine when you get it back together. (bearings)
Old Apr 29, 2007 | 01:49 PM
wrd1972's Avatar
Yest this works well, I would add to lube the inside of the hub and use an impact.
Old Apr 29, 2007 | 02:07 PM
seawolf06's Avatar
We figured out it was the PS pulley, not the crank pulley.
Old Sep 4, 2007 | 06:22 PM
DirtyDaveW's Avatar
What size is the all thread and where did you buy it? Is it metric or SAE?
Thanks,
Dave
Old Sep 4, 2007 | 06:47 PM
ricehammer's Avatar
Thanks,
Dave
7/16" - 20 threads/inch and McMaster Carr (www.mcmaster.com). DO NOT use an impact wrench. A gear wrench works well and you don't chance damaging the crank threads.
Old Sep 4, 2007 | 07:20 PM
DirtyDaveW's Avatar
Dang! Nice site! I'll bookmark this thing. I'm always needing some odd nut/bolt.
Thanks !!
Old Sep 4, 2007 | 07:34 PM
DirtyDaveW's Avatar
Just ordered it. Thanks again.
Roadie
Feb 16, 2015 10:34 AM
cyteone
Feb 7, 2015 06:04 PM
Lions3
Aug 30, 2002 01:03 PM
FASTFATBOY
Jul 6, 2002 01:02 AM
