what should my oil pressure be? (385 LE2)
Old Apr 20, 2007 | 09:19 PM
rawbutt's Avatar
just got my LE2 setup going in my 385 and wondering what normal oil pressure should be...seems a little low to be but not sure. after the car is totally good and warm, it will read just a hair below the 20 line at idle in drive....at normal road speed, it's anywhere from 20 - 40, but doesn't really go much above 40 even with the rpm's up after it's good and warm.
thanks!
Old Apr 20, 2007 | 09:34 PM
What oil pump/pan is in it? Idle pressure does not sound bad.
Old Apr 20, 2007 | 09:41 PM
rawbutt's Avatar
shoe...thanks for the prompt reply....
pretty sure i'm running a melling high volume pump and stock pan
Old Apr 20, 2007 | 09:57 PM
Many people warn against running an HV pump with a stock pan. There are threads all over this board about it. It may not be sucking your pan dry at low RPMs, but sometimes cavitation can be an issue. Some like to chamfer the oil intake hole in the rear main cap to decrease chances of cavitation.
Old Apr 20, 2007 | 10:04 PM
rawbutt's Avatar
shoe....
thanks for bringing this to my attention....i am going to look into it and talk it over with my mechanic.
thanks!
HectorM52
Jul 30, 2017 11:46 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
