Way to measure cam dowel pin legnth?....
Old Apr 27, 2007 | 09:21 AM
CrazyLT1's Avatar
Hey guys,
I am changing my optispark today, and was wondering if there was a way to measure the legnth of the cam dowel pin while the cam was still in the car. Car is a 1997 so the length matters. I think my opti failed pre-maturely so I want to check it.
Is there a way to measure this legnth without removing the cam? And how long should it be?
Old Apr 27, 2007 | 09:34 AM
bmwmcars's Avatar
maybe something like a tire tread depth gauge? or a set of calipers....
Old Apr 27, 2007 | 10:12 AM
DirtyDan's Avatar
There are plenty of calipers out there that could measure it for you. Just find somebody that works with lathes or in a machine shop.
Old Apr 27, 2007 | 10:31 AM
94_PatriotRed_Z's Avatar
I have heard of people putting alittle bit of grease or clay in the opti and put the opti up there, then see how much of an indentation the pin made into the clay
Old Apr 27, 2007 | 08:50 PM
hogs's Avatar
How far should the pin go inside the opti is 100/1000 enough? or??
Old Apr 27, 2007 | 10:46 PM
It should probably go at least halfway into the slot. Two-thirds might be be better.
Old Apr 28, 2007 | 07:09 AM
hogs's Avatar
So lets say if the pin Sticks pass the 3 cam bolts about 100/1000 that wd be enough to go into the opti??
Old Apr 28, 2007 | 08:33 AM
Impossible to say, because you don't know how close the opti drive comes to the face of the cam gear. Just mock it up with clay already.
Old Apr 28, 2007 | 04:42 PM
hogs's Avatar
OK but I have heard from respectful enigine builders just double checking that as long as it comes out pass 100/1000 pas the bolts thats more than good enough... Thats why I was asking...Anyone else agree to this?
Old Apr 28, 2007 | 06:53 PM
The way to measure it is from the face of the cam.
Old Apr 28, 2007 | 08:58 PM
hogs's Avatar
YEs I did know that thanks for the input I was just checking the other way.. Mine is about .620 from the face...
So that should be more than good enough to go with ?
Old Apr 28, 2007 | 10:04 PM
My stocker was ~ .650", but your should be ok.
parkers Z28
Mar 11, 2016 08:14 PM
sscott
Jan 17, 2015 04:30 PM
Jul 4, 2005 05:00 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
dansam
Jul 20, 2002 01:10 PM
