Oil Pressure low after CAM install
Old Apr 23, 2007 | 04:01 PM
johnnyb's Avatar
i finally got everything straightened out with my car, but now i have a new problem. i was about 15 minutes away from my house, and i noticed the oil pressure dropping. it would always idle at roughly 30psi, but i noticed it was a little lower. it went down to 20 at idle, then 15 after a few more minutes, and slowly going down at idle until i finally pulled into my driveway when the gauge dropped all the way down! first thought- spun bearing. but wouldnt this have happened all of a sudden, not slowly after 15 minutes? oil is leaking a little bit out the back of the oil pan (just changed the gasket, but we all know they are a PITA). could that equate to my low oil pressure? thanks in advance
Old Apr 23, 2007 | 04:20 PM
An oil leak does not cause low oil pressure (unless there is not enough oil left to pump).
Old Apr 23, 2007 | 04:29 PM
BradcTA's Avatar
Sorry to be the one to tell you this but it's probably a spun bearing. Can you here a knocking/rattle reving it up between 1500-2000 RPM? I drove mine for 2 hrs and it jst died on me=no oil pressure
Old Apr 23, 2007 | 05:33 PM
johnnyb's Avatar
no knocking/rattling or any abnormal noise. i just went out to check it again, and it seemed to idle fine with good oil pressure maybe its just the sensor?
Old Apr 23, 2007 | 05:42 PM
Mike96z's Avatar
Maybe engine got hotter than normal, which will cause lower pressure + if thats not the case, BAD CAM Bearings will cause lower pressure, sure you didnt scar one installing it or were they high mileage bearings? Should replace them with the cam.
Old Apr 24, 2007 | 05:20 AM
johnnyb's Avatar
it overheated the day before pretty bad- could that have anything to do with it? also- the oil seems very very thin. im gonna change it for some heavier oil.
Old Apr 24, 2007 | 08:00 AM
Z28LT1_Just_Nasty's Avatar
How old is the oil? I would check it for any bits of metal or debris if you could, that would be a better indicator of damage.
Old Apr 24, 2007 | 08:42 AM
johnnyb's Avatar
oil has 30 miles on it. i will change it as soon as i can
Old Apr 24, 2007 | 08:57 AM
Javier97Z28's Avatar
Moderator
Could be the sensor if it's varying so much...
Old Apr 24, 2007 | 11:28 AM
wrd1972's Avatar
Worn bearing clearances.
Old Apr 24, 2007 | 12:30 PM
seawolf06's Avatar
Yep, I spun mine not 400 miles after the cam swap. Low oil pressure was the first sign and it was all downhill from there.
HectorM52
Jul 30, 2017 11:46 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
