Stock head casting flow numbers
Old Apr 24, 2007 | 05:06 PM
mdacton's Avatar
Who did your heads and how does it run?
I would just like to hear some opinions with what you have and how it runs......Without turning into a big debate
considering a stock type bottom end, 374 casting ported and a custom grind......The car can be as nasty as anything but I want to get tags on it so I can run street classes.
Currently 3200#
Car is built to race and may need a new converter....has a 9" 4500 in it now
Old Apr 24, 2007 | 05:46 PM
96capricemgr's Avatar
AI 190cc heads
.100 70/60
.200 146/115
.300 202/153
.400 244/172
.500 268/187
.600 275/193
4.030 bore not a 4.060 as some vendors listed and 2.00/1.56 Ferrea valves
Times are in sig. This is first and foremost a street car though 3400/3.73s 27" tires. I learned a little over the winter and hope it goes a little faster with that knowledge applied, will see when I get it to the track.
Old Apr 25, 2007 | 10:33 AM
mdacton's Avatar
Good point.....This will be a 4.030 bore
Old Apr 25, 2007 | 11:02 AM
Z-RATED94's Avatar
Lloyds heads from 3 years ago, before stages and the improvements he has made since.
.100 65.2 54.1
.200 137.2 109.4
.300 199.0 153.5
.400 241.1 174.1
.500 265.3 185.7
.600 268.8 192.5
The car so far has gone 12.64 in 95 degree heat with no track prep and some severe valve float. Full weight. This is also with a very small Joe O. cam. With the beehives I have picked up 500 more rpm and will have a better suspension set-up, including a set of MTs on some Bogarts. Looking for very high 11's, and then will spray it with a 100 shot. Stock 29k shortblock.
Old Apr 25, 2007 | 01:33 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
PortPros, Austin, TX
Intake:
.100-------61.9
.200-------89.1
.300-------173.8
.400-------220
.500-------253.6
.550-------264.3
.600-------273.9
Exhaust:
.100-------58.3
.200-------115.3
.300-------147.1
.400-------174.00
.500-------181.8
.550-------185.5
.600-------185.9
Numbers and times in sig
Old Apr 25, 2007 | 01:48 PM
Colin91Z's Avatar
CHS heads www.cylinderheadspecialties.com
561 castings, 2.0/1.56 valves
28" water, 4.0 bore
I/E
.100 65.9 /55.4
.200 134.4/103.1
.300 191.8/141.2
.400 232.3/163.6
.500 260.0/181.9
.550 268.6/186.8
.600 271.6/190.8
I don't know how it runs yet, but I will be finding out by the end of next month. Motor info is in my sig
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
parkers Z28
Mar 11, 2016 08:14 PM
*Emilia*
May 13, 2015 09:05 AM
MadMav
Feb 6, 2015 11:02 PM
