how much stall?
Old Apr 25, 2007 | 04:18 PM
red1984's Avatar
how much stall?
I'm going to be installing a cc503 cam in about a month. How much stall am i going to want with that cam? I plan on going with a yank.
Old Apr 25, 2007 | 05:05 PM
vin1382's Avatar
i did a 2800 midwest stall that i am regretting at this point. fairly gutless in the low end. im going to be upgrading to a 3600 yank.
Old Apr 25, 2007 | 09:17 PM
snakeatinZ's Avatar
3200 Fuddle. Yank quality, yet sooo much cheaper.
Old Apr 26, 2007 | 08:51 AM
snareman's Avatar
stall
I got a midwest 2800 stall does fine for me, of course: I dont have ported heads.should work fine with the hotcam and Macs I am getting!
Old Apr 26, 2007 | 10:56 AM
WhiteLT1z's Avatar
Nothing below a 3200. I went with a 3600 Yank and that cam.
Old Apr 26, 2007 | 11:19 AM
jeepbeast's Avatar
do you have a shift problem with that high of a stall in the 94? i thought 94's had a shift issue with stalls above 2800 or so?
Old Apr 26, 2007 | 12:32 PM
WhiteLT1z's Avatar
Dunno, since i haven't had the combo together yet. I still have to send the tranny off to CPT and drop the motor in before i can start it.. Hopefully if I do have any problems it woun't be anything i can't tune out w/ LT1 Edit.
Old Apr 26, 2007 | 03:28 PM
2000GTP's Avatar
You could always give your exact combo to the converter company that you plan to purchase from and they can give you their recommendation as well.
Old Apr 26, 2007 | 05:32 PM
red1984's Avatar
what do most people shift at with the cc503. I called yank and they told me that if i shift at 6500 rpm, i should get a 4000 stall. that sounds like it would be too much for my setup.
Old Apr 26, 2007 | 09:41 PM
snakeatinZ's Avatar
Dont listen to people who have never owned a LT1. Trust us, You need a 3200 to a 3600 stall. A Fuddle, performance series 3200 - 3600 would be ideal for you. With a 3200 stall you are going to leave the line at 2800 - 3000 rpms.... Right where the cc503 begins to make some real power. Shift at 6200 and you will run mid to low 12's, cam only with all bolt on's. You cant go wrong.
Steve
Old Apr 27, 2007 | 02:36 AM
revtime's Avatar
Don't be afraid of the stall.
I run a 4k Coan converter in a bolt on (stock internal) LT1.
Its almost too much fun.
Old Apr 27, 2007 | 08:30 AM
Z-RATED94's Avatar
Not to jack this thread but, what size gear, tires, and rpm are you turning at the finish line?
Old Apr 28, 2007 | 02:35 AM
revtime's Avatar
It was a 3.73 gear with 26 inch tires. Unfortunately I never got to the track before I broke the 10 bolt rear.
Now I have a 4.10 spooled 12 bolt getting ready to go in the car with 28 inch tires.
I have the rev limiter set at 6250 so we shall see if I run out of gear.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
