k, i need help fast!!! please!!!
Old Apr 23, 2007 | 01:07 PM
tastyZL1's Avatar
ok guys well i just did all of the mods in my sig over the weekend, everyting was going smooth and what not, and i finally got the engine all put back together and then this happens......it has open headers by the way when i was trying to start it
so my thoughts are 1) lifters are deflated 2) opti is on wrong...3) i have no idea and im completey screwed. and i also forgot to mention when i put the cam on and new timing chain on the #1 piston was at top dead center and the timing gears were lined up perfectly, so someone please help me and give me somewhere to go.. thanks everyone
Old Apr 23, 2007 | 01:33 PM
Ironxcross's Avatar
sounds like a bad drum solo, lol. did you get a tune for all those mods, if not, that could be it right there.
Old Apr 23, 2007 | 01:34 PM
oneclean97z's Avatar
sounds possible to me
Old Apr 23, 2007 | 01:38 PM
tastyZL1's Avatar
that was the first time trying to fire it, and there is no tune yet
Old Apr 23, 2007 | 01:41 PM
camzaro28's Avatar
I dunno, I just did mild heads with the crane 227 and it started right up and I am still not tuned.
But, no lie, after hearing it trying to start.............I thought you had music playing. WOW, I feel for ya man, hopefully someone can lead you in the right direction.
Old Apr 23, 2007 | 01:51 PM
Javier97Z28's Avatar
Moderator
Rockers might be too tight
Opti may be on wrong
It's *very* hard to tell from that video. Get a better quality video up.
It should at least start w/o a tune....
Old Apr 23, 2007 | 01:54 PM
tastyZL1's Avatar
hey camzaro28 do you have a sound clip of your car? id like to hear it, i really think my opti got put on wrong cuz when it was taken of by my friends friend, he didnt mark where the teeth were and plus when we were putting it on we had to shift it a little bit to get it to fit
Old Apr 23, 2007 | 01:55 PM
tastyZL1's Avatar
how can i fix the opti, what is the right way to line it up?
Old Apr 23, 2007 | 01:57 PM
Moderator
There's no need to "mark" anything. It only goes on one way correctly, no guessing. See below.
Courtesy of shoebox:
http://shbox.com/1/93-94_opti.jpg
Old Apr 23, 2007 | 02:02 PM
tastyZL1's Avatar
so if my opti is already on, then its fine theres no way its on wrong?
Old Apr 23, 2007 | 02:06 PM
Moderator
No, it can very easily be put in wrong. This is the first thing I would check, especially if little attention as to "how" it goes on was given.
What I was saying was there's no reason to mark it, as this is the correct way that it goes.. it's already "marked" from the factory.
Old Apr 23, 2007 | 02:09 PM
tastyZL1's Avatar
oh ok i got ya thank you
Old Apr 23, 2007 | 02:18 PM
NovaTodd's Avatar
When you put in the cam did you replace the timing set (gears and chain)? Later years (95 on) don't use the spline type drive. If you installed the HD set from GM, you aren't getting anything to drive the distributor. And yes, I have seen it happen before.
Try pulling the opti off and then put the splined drive back into the timing cover. If you can't feel it grab anything, pull the timing cover off and check the timing gear for the splines....my $.02
Old Apr 23, 2007 | 07:10 PM
Mtrhds94Z's Avatar
When aligning the splined shaft pay close attention to where the missing tooth is.. what I do is take just the stub shaft[not in the opti, or the TC] and feel gently where the 'notch' is in the TC..[where it finally slides in easty.. turn it one tooth at a time til you find that..]
Then remember at what 'o'clock' it went into the TC.. [or make a little sharpie mark]then take the shaft, and insert into opti, and do the same thing til it goes in EASY into the opti.. then turn the opti til it's as close as you can get it to where the 'o'clock' was to match the TC.. then with the shaft still in the opti gently install opti and keep trying, turning it SLIGHTLY [the opti or the shaft.. it's easier to tilt opti slightly more each time if it doesn't go in ] until it slides in EASY.. NEVER pull it on with the 3 bolts.. it should slide in, and go flush/tight to the TC without any gap when it's on right.. and yes it's fairly easy to get it on wrong, and it will go on wrong.. tho usually it won't slide on easy .. many make the error of drawing it on with the 3 mounting bolts.. if it slides on and sits flush/snug to the TC [without pushing or drawing w/bolts]it should be correct..
Old Apr 23, 2007 | 10:03 PM
tastyZL1's Avatar
thanks everyone for the help
