Rocker Arm tightening help needed!
Old Apr 21, 2007 | 05:59 PM
KuruptWS6spd's Avatar
Question Rocker Arm tightening help needed!
1993 LT1 Trans Am....
Can someone run me through tightening the rocker arms down? I need to know the spec and the procedure. It seems to me there is more then just tightening them down to spec. Any special order or procedure?
Thanks in advance,
Tom
Old Apr 21, 2007 | 06:17 PM
ttop1986's Avatar
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Apr 21, 2007 | 08:49 PM
hairbear21's Avatar
I found that instead of spinning the pushrod, I had better luck feeling for up/down movement. I tried the spinning and went 1/2 turn and it was WAY to much. I tightened them to where there is no up/down movement, and then went 1/2 turn. Runs like a dream.
Parts Wanted
Mar 17, 2015 11:24 PM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
mjcent922
Jul 27, 2002 12:42 PM
