input on Crower Enduro series full roller rockers
Old Apr 23, 2007 | 11:45 PM
pat35's Avatar
was getting ready to buy a set of comp cam rollerrockers [1305-16]. does anyone know if the Crower Enduro series full roller rockers are as good as the comp? these are used and have about 5k miles on them. look like they are in great shape . can you rebuild these in the future? any input would be appreciated! they will be going on a 95 lt1 firebird.
Thanks!
Pat
Old Apr 24, 2007 | 12:12 AM
MachinistOne's Avatar
The Enduro's are better than the Comp's.
Old Apr 24, 2007 | 04:32 AM
SS RRR's Avatar
Because... ?
Old Apr 24, 2007 | 06:29 PM
pat35's Avatar
they turned out to be 1.7 i nead 1.6 for a 305 cam
Old Apr 24, 2007 | 06:34 PM
mdacton's Avatar
Originally Posted by SS RRR
Because... ?
alot higher quality pc.
Old Apr 24, 2007 | 07:41 PM
Yep - Comp tried to copy the Crower, I am ok with using the Comp's with a street hydraulic motor, but with a race solid roller they don't hold lash.
Old Apr 25, 2007 | 11:35 PM
SS RRR's Avatar
Thanks for the info. How about a solid roller street/strip engine?
Old Apr 26, 2007 | 07:42 PM
pat35's Avatar
you gys bin grate
Old Apr 26, 2007 | 07:54 PM
I wouldn't use them with a solid roller.
Old Apr 26, 2007 | 10:13 PM
SS RRR's Avatar
Will the Enduros w/ adjusting nuts (7/16 stud) clear a stock LT1 valve cover?
Old Apr 26, 2007 | 10:18 PM
mdacton's Avatar
I'm not 100% sure but I don't think so, I know someone that had used them with the LT4's...I have them but I have big fabbed valve covers
Old Apr 26, 2007 | 10:31 PM
SS RRR's Avatar
Thanks... I'm trying to keep the engine looking as stock as possible and would like to stay away from fabbed VC's. However I might be up for the LT4 valve covers. Would like to know for sure though.
Old Apr 27, 2007 | 12:26 AM
Use the Crane Gold narrow body rockers.
Old Apr 27, 2007 | 05:56 PM
SS RRR's Avatar
I'd much rather stay away from aluminum rockers. I'll check to see what my machinist recommends and compare notes...
Old Apr 27, 2007 | 06:02 PM
mdacton's Avatar
I think my crowers are a little smaller than pro mags....not as wide. I can check them if you want. I was just told they wouldn't clear the tin stock covers....
