Thunder Racing OTVC Plug Wires
Does anyone have the OTVC setup that Thunder Racing sells? It comes with 8mm Taylor Wires and all the hardware needed. Just wondering about the quality of the kit and if it was the one to go with. Are there any other options out there?
i got them and they are great. tips for making the ends.
take a drill bit and lightly hone out the inside, next boil the black ends in water to loosen and use grease or soap to slide the wire in, be careful and not to do too much bending.
i have made 2 sets already.
here is the thread I was talking about OVC Wire Lengths
I found those lengths to be a bit too long. I have my wire seperators "upside down" with the wires to the top side of the valve cover and they're still too long on the rear cylinders.
I didn't have any problems assembling the wires. Just crimp the connector on very tight, put some grease on the inside of the opti end and slide the wire in as much as possible. When it stops, just use some long needle-nose pliers and pull it through the rest of the way.
grabbem88
Mar 18, 2015 01:25 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
