Could vacuum leak cause DTC 64 code ????
Old Apr 22, 2007 | 07:44 PM
AZ2ENVY's Avatar
I just got a vacuum leak around the PCV area of the manifold and
i drove it down the block and back with the vacuum leak still . DTC
64 was set through the scanmaster with no SES light . I let the car idle for a few mins and the SES light came on . I gave it a little gas and immediately the SES light shut off but the code is still in the scanmaster . The 02's
have less than 100 miles on them BTW . Could the vacuum leak cause
the DTC 64 ? Thanks in advance
Old Apr 23, 2007 | 05:41 PM
Any air that bypasses the MAF sensor is forcing the PCM to correct the lean condition using the long term fuel corrections. A small leak should not be a big problem. It would have to be so big that the PCM could not correct the condition using both the long term and short term fuel corrections, causing the O2 sensor to indicate a lean condition for an extended period of time.
How big is the vacuum leak at the PCV valve?
Old Apr 23, 2007 | 08:27 PM
AZ2ENVY's Avatar
It was so big right when you shut the car off the whistling of the leak
was VERY evident for a solid 3 seconds So im assuming this leak is big enough to cause this DTC . You could also hear the leak plain as day when
the car was running with MAC mids , no cats or mufflers , CC XE 233/239
cam . So the car is in NO way quiet and you could hear the leak with the hood down .
Old Apr 25, 2007 | 08:55 PM
AZ2ENVY's Avatar
Any thoughts ???
Old Apr 26, 2007 | 05:12 AM
Guest47904's Avatar
Guest
Any thoughts ???
Any thoughts? About what?
The answer was yes, a 64 can be caused by a leak.
You said you have a definite leak. Did you cure it?
When a 64 is set, the SES comes on. If you are seeing the light go on and off, the code is coming and going. That would indicate you have a problem like hambone. Lean at idle but not when the revs are brought up.
He also sees a few other things. Fuel trims eventually max out and IAC count goes to 0.
He found one leak but still has not found all of them.
Old Apr 26, 2007 | 06:47 PM
AZ2ENVY's Avatar
Well he asked me how big the leak was so i was just curious what he thought
up when i answered him . Yes i fixed the leak but havent got to drive the car yet
Old Apr 26, 2007 | 09:35 PM
Your description of the leak is fairly subjective... hard to say with absolute certainty that it is the only cause of the problem. But fixing it is a step in the right direction.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
lt1matt
Mar 21, 2015 07:35 PM
CARiD
Jan 27, 2015 06:27 AM
91Bird305
Aug 5, 2002 01:39 PM
JurisAg02
Jul 27, 2002 11:49 AM
