cam install questions need help fast
Old Apr 20, 2007 | 10:12 PM
tastyZL1's Avatar
i have a crane 227 cam, and a 93 lt1 motor, on the front of the cam where the timing key sticks out it sticks out farther than the one on the stock cam shaft, should i grind it down to the same size, or tap it in? and with what ever i do should i heat it or what? thanks for the help
Old Apr 20, 2007 | 10:16 PM
VK's Avatar
VK
The dowl pin is what you mean. And it needs to be the same length as your stock cam or it will wear on the back of the opti-spark and ruin it pretty fast.
First try to hammer it in. If that don't work file it down, but try to get it as close to the same length if not a TINY bit shorter then your stock cam.
Old Apr 20, 2007 | 10:28 PM
tastyZL1's Avatar
thanks VK and i couldnt remember what that was called for the life of me
Old Apr 20, 2007 | 10:30 PM
VK's Avatar
VK
lol, i know what you mean....
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
