View Full Version : LT1 Based Engine Tech
- Rattle and pop under my Z
- Exhaust
- Just Got Mods Done And Have ??????????????
- Changing from 2.73 ->3.73 Richmonds= Whine?
- mechanics help please.....engine idles (rough) but dies when i push on the gas
- question about kooks headers
- Cmotorsports phone #
- Coarse,grinding-rattle
- Waterpump failure...
- Anyone had any success "home porting" there LT1 castings?
- does this sound bad to u?
- Anyone got Loyd Elliots Phone Number??
- plug gapping
- Mallory Hyfire #685 on a 97
- Over heating problem??
- No Oil Pressure
- How do you check for a vaccum leak??
- Found my Vaccuum leak :)
- swapping drivetrains, '95 to '97 and '97 into '95
- Opti Spark test?
- what would happen if the FP was connected..
- valve spring question!
- Harmonic Balancer vibration...
- Impala short block?
- Cheap Lifters
- Procharger + Hotcam=??
- lt1 header bolt pattern
- Replacing water pump gear... how?
- Edel Brock Headers
- 1.6 RR swap parts
- Low BLM readings after startup...why?
- For those who has a supercharger
- Lt-1's With High Mileage Running Stock Oil Cooler!
- Scanmaster readings
- Help with finding part# for plug wire divider.
- performance shocks?
- brake light on instrument panel
- please help
- Couple of performance questions
- Cam Me!!!!
- Not passing smog- Here are the codes... help please!
- Two Simple Questions about an Intake
- Would a leaking/blown head gasket make the car undrivable?
- I need 550 to the rear wheels
- Well, looks like that clean spark plug means head gasket, NEED BIG HELP!
- Ram-Air Questions???
- Where do you guys go to get coolant system presure tested?
- What y pipe for jet hot hooker headers?
- Very Weird: door locking/unlocking
- whats wrong with my car
- Stock Valve cover clearance and 1.6 Pro Mag
- Porting an LT1 intake..
- HELP QUICK should I buy this car??
- LT1 timing chain concerns,
- .:Catalytic Converter Questions/best Prices?:.
- stock lt1 to 383 stroker???? Help
- Former import owner needs help with 94 Formula
- bad o2 sensor of heater? dtc codes 13 and 63
- Is there any way to install the timing cover without dropping the oil pan?
- Header Bolts Part #'s??
- Beefing up Suspension?
- What type is this NGK plug......
- how to use a 93 opti on my 97 or a 97 opti on a 93
- Loss of High RPM power/stops pulling
- Very odd Starting Problem...
- question on which grade octance gas is optimum for the lt1
- Car seems to be misfiring/no power/happens sporadically. Optispark? Any ideas?
- code 0400 and 0410
- welp, i'm boned. broke crank hub while on the car
- looking at MAC mids... any input?
- Car Surging and Engine Light Occasionally On
- Having problems......can't figure it out????
- Gap of spark plugs.
- MAF and SES
- Which Thermostat?
- bad 02 sensor?
- False Knock?
- Any way to get oil on the cylinder walls?
- Best flowing California legal headers?
- Defroster Question
- Finally broke into the 12's -------Barely
- Need help low 230/236 AI heads dyno results.
- Shoebox need your help right quick!!
- 383 Questions, please advise...
- Headers don't fit
- Stumped
- Ignition switch!!!
- LT-4 knock module
- Golen Engine question
- Newbie Launching Question
- impala head gasket #12553160?
- vacuum line! where does it go?
- Engine swap/wire harness question
- coolant temp sensor..how to check?
- Need help to restart my Rebuilt Motor!!!!
- Weird mis-fire problem
- Delteq install question
- Valve Springs
- Guage faces
- 1.6 RR install parts list
- stock bottom + afr heads == et?
- Cylinder Head (flow #'s)
- Got an STP oil filter, but noticed it was shorter, any problem with this?
- Changed my LT1's plugs today, one came out super clean?????
- Could have some problems...
- head gasket question
- How fast should i run at the track????
- Can a bad o2 sensor affect BLM readings?
- Let that be a lesson to me...
- headers
- correct pushrod length for Comp R lifters?
- Low Voltage
- My airbags deployed and I have new ones and a control module...
- Shoebox, can you help a brother out?
- Interesting article
- ltx heads...
- Where to get parts for my LT1 short block rebuild?
- Hypertech PP3 cable
- Dyno Results
- Clunking noise from engine bay.
- [B]Aermotive Sucks !! Thanks Racetronix[/B]
- Problems after driving through water
- Need LT1 Advice!!
- Oil Pump Pick Up Fell Off
- injector install - help please
- Cracked head. What are my options??
- Got My Car Dyno'd
- Keep car lasting as long as possible.
- EGR question
- What if (electric water pump ?)
- rev limiter question
- Larger Throttle body
- How long do I have before the opti's shot?
- Fuel Problem HELP!!!
- A Different #1 Primary header questin
- Header Vibrating Agaist K-Member - Suggestions?
- Picture of your 93-97 with the Hooker Super Comps on
- LT1 head pictures
- pacesetter long tubes
- Camaro Part Numbers Manual
- Lengthen MAF wires..????
- Problems After Jet-Hot LT install
- EGR Malfunction
- Fittong Walbro 22 in stock bucket
- Best plug choice/gap for mostly stock LT1?
- Need to quiet this baby down...
- Track Results...
- Will a miss thorw a code?
- What mods to beat friends 2003 Mach 1 mustang?
- water pump drive bearing...
- need help diagnosing ses light
- A couple questions..melling and rod/main clearance
- Racetronix Fuel System what do i need??
- Moving ahead after blown motor
- How reliable is temp sender?
- a motor full of water :(
- All opinions, ideas, etc. welcome........
- New car difficulties
- Bad Sensor or Computer Error???
- Pistons
- bigger throttle body
- Electrical/Starting Issues -- Any Ideas (Did a search)
- Abs Inop
- Is there a special way to install a big cam in a LT1 383?
- Help With Emissions Results
- what else do i need to fire my LT1??
- Need help with cooling fans, not turning on
- broken exhaust bolt
- LT4 Extreme Timing
- Engine stand bolts?
- LT1 Trans temp gauge
- problems after bbk throttle body install !
- Soon to buy Eibach pro kit spring set, Recomendation on Shocks?
- Oil leak FOUND. Help please!?
- Softest front springs for my LT1
- Have a miss at Idle
- Rear Main Seal Leak?
- Carfax Report Needed
- Water Wetter????
- What kind of gas mileage do u get with an LT4 hotcam?
- Wheres a good place to have heads ported?
- 383 strocker: what cam to use?
- Top end technical info
- 97 motor how to convert to 95
- HP gains from P&P Stock Heads
- Coated MAc headers!
- "Home" porting guys please help?
- rod hitting bottom of oil pan with dent. Should i be worried?
- VSS Connector doesn't fit
- piston recomendation?
- Replace H2o Pump - How to???
- 96 ws6 throwing codes after header install
- Anyone have the zz-x cam?
- RED ALERT! LT1 in distress!
- low oil light, but oil is full
- Overheating - Help Please Help
- Anybody else have these RPO codes?
- Oil leak right behind the driver side door?
- Help with basic Mallory 685 setting?
- Is 1 cutout on the ORY as good as 1 after each header?
- LS1 radiator in LT1?
- Anyone Have 95z28 6speed, I Need Help
- Fuel injectors?
- Et
- Stock Head Specifications?
- Loudmouth or GMMG
- OBD-11 tuning software not Autotap
- Changing Plugs And Wires On 93 Lt1
- VERY quick K&N Re-charge question
- New setup net me 3mph?
- Another guess my dyno #' thread
- what size ET Street do i need?
- How can I ABSOLUTELY be sure that I am getting a '96 SS?
- got one for you shoebox
- what to do next?
- where is the fuel pump relay?
- Quick fuel pressure question.
- What are the advantages of stepped headers?
- 1995 Z28 bad distribution system / opti-spark?
- Custom PCM tunning
- Another casualty of a cam change...
- Possible Dyno #s
- Proper Coolant Ratio
- I need reasons for this...
- Synthetic Oil
- AS&M headers...made my own off-road pipe...(picture inside)
- Just need alittle advice formy LT1
- What is the proper break-in procedure for a new motor?
- Fitting the Holley Stealth Ram to LT1 heads?
- Breaking problem
- rocker stud girdle
- weird 98-02 firebird pop up headlight problem im stumped
- madwolf around?
- Low CR pistons change air/fuel mix?
- Stainless Works Y-pipe install went SMOOOOTH!
- Changing pistons????
- SLP header gasket
- Intermittent electrical failure! Help!
- 7/16" studs for Comp Cams Pro Mag
- Distributor Question
- Throttle cable adjustment (with TCS)
- Fan switch question i guess?
- Installing Pacesetter Longtubes
- Tall Center Bolt Valve Covers
- LS1 exhaust on a LT1 car?
- Very pleased with 1.6rr's
- dumb dyno question, but here goes...
- question on the hose from header to manifold ?
- Hard Start, And Some Times No Start
