welp, i'm boned. broke crank hub while on the car
Re: welp, i'm boned. broke crank hub while on the car
time to get a torch and heat that beast up, youll need to replace the front seal though.
thunderracing sells new hubs for 85$ - 50 after the core return, so 35 bucks.
edit: but i dont know if they will take a broken hub as a core.
Originally Posted by shoebox
Were you using the correct procedure when trying to remove it?
Weld the ear back on and try again.
The reason the pulley is laying on the balancer is I was trying to think of ways to get the hub off with only two ears. I went and pulled a different hub off, a different LT1 and it came right off. I dunno, Caming this car is turning into quite the adventure.
Time for a big focking hammer.
When i couldnt get a puller to work, i took a 3 foot iron bar and put in behind an ear of the hub, and infront of the sway bar. Then had a friend pull on the top of the bar, while i tapped the ears of the hub tward me with the hammer. Slow but sure it came off.
Here's my bright idea. It's a really cheesy "photoshop" but who cares. The holes will be threaded and I can just use my puller again, if it doesn't work onto the new ideas. Tell me if anyone see's a problem with this. The horseshoe type thing will go behind it and kinda replace the 3rd ear and hopefully pull it off.
http://stlsr.jwitech.com/media/uploa...eThisWorks.jpg
I'm looking at the two crank hubs I have, is there a difference between the Caprice LT1 hub and the F-Body LT1 hub. They're shaped slightly different, but I can't imagine them being any different.
