Help with finding part# for plug wire divider.
Old Aug 16, 2004 | 10:15 AM
gearheads78's Avatar
Question Help with finding part# for plug wire divider.
On an LT1 the separator / sheild that helps keep the wires tidy behind the steering pump and above the AC compressor.
Its a "L" shaped piece the wraps around the accessory mounting bracket. If you don't know a part number if you do know GM's name for this piece. I was in my parts dept for 15 min this morning and they could not figure it out.
It looks like this
Richard
Old Aug 16, 2004 | 10:25 AM
PoorMan's Avatar
Re: Help with finding part# for plug wire divider.
You could always check the "u-pull-it" junk yards. I have found several hard to find gizmos like that at these places.
Old Aug 16, 2004 | 10:48 AM
944v8inDFW's Avatar
Re: Help with finding part# for plug wire divider. Calling Shoebox
Yes i would like to find that myself as well.
SHOEBOX
OH Mister Shoebox............
Old Aug 16, 2004 | 11:33 AM
I have not been able to come up with a p/n for that. I wanted one, myself.
Old Aug 17, 2004 | 08:50 AM
I added a link to a pic. I am sure someone has to know at least what it is called so it can be looked up. Most of the cars I have seen it is broken or missing. I don't think finding a used one will be very easy.
Old Aug 17, 2004 | 10:14 AM
n2ceptor's Avatar
Heres one Shoebox can add to his list....
93-97 LT1 GM Part # 10223670... Found in Group Two, Generator Mounting, part #5...
GMPartsdirect.com shows it cost around 3 dollars....
Old Aug 17, 2004 | 10:26 AM
That's not it. I have looked there. That's the one just above the tensioner. See how it has the bolt going through it to mount it? (hard to see in my pic, but the parts book diagram shows it) What you found is #53 in this diagram.
Old Aug 17, 2004 | 10:27 AM
1fastlt1's Avatar
I saw that one too but I don't believe that is the correct part! That appears to be the one just as the wires come out of the opti. I looked through every freakin page in the parts catalog and didn't see it listed one time!
Richard
n2ceptor's Avatar
Well, i tried...
Fatdog2
Feb 13, 2015 08:19 PM
Jazsun
Dec 29, 2014 12:14 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
