whats wrong with my car
Old Aug 15, 2004 | 09:48 PM
jadams94ta's Avatar
I took my car out today and my guages started to jump around -> the speedomoter, tach, and voltage guage. Also, when I try to start my car, it doesn't start the first time, I have to turn the key off and then try again for it to start. None of the turn signals work, either, but the hazard lights work. any ideas
thanks
jason
Old Aug 15, 2004 | 09:56 PM
944v8inDFW's Avatar
Re: whats wrong with my car
sounds like a bad chassis ground. Not sure where to look as i am a transplanter not an Fbodyer. Check out Shoebox's site maybe there is some good info there.
Old Aug 16, 2004 | 08:47 PM
jadams94ta's Avatar
come on guy if i dont find out whats wrong with my car i cant get it tuned . so i go out to mess with it today and the car wont strat wont even turn over
Old Aug 16, 2004 | 09:01 PM
944v8inDFW's Avatar
like i said bad ground battery cables or maybe fusible links
NOW broooother and sistaaaa's lets turn in the good book of Shoebox, Chapter 14 verse 7
http://shbox.com/1/fusible.jpg
Old Aug 16, 2004 | 09:09 PM
jadams94ta's Avatar
i checked all the stuff today and it look all ok
jason
Old Aug 16, 2004 | 10:01 PM
kingman109's Avatar
hmmm first part sounds like alternator going bad - mine would cause gauges to jump all over place- but i dont see why your turn signals dont work
Old Aug 16, 2004 | 10:43 PM
jadams94ta's Avatar
i just need to find out whats is wrong with it . it's going to get tuned friday and it really needs to go
Old Aug 19, 2004 | 08:33 AM
So, is it not starting, now? Does it crank or crank but not start? Gonna need some details if you want anyone to try to help. List all troubleshooting steps you have taken so far.
Old Aug 19, 2004 | 09:07 AM
QUASARBLUEZ28's Avatar
Like Shoebox said "more info please" also...................
Might check those battery cables. They can corrode on the inside and you would never see it. I've seen this happen many times. You can have good voltage without the amperage.
http://community.webshots.com/album/33786390mmhudJ?888
Old Aug 19, 2004 | 03:38 PM
jadams94ta's Avatar
it not even cranking over the fuel pump dont came one, gauges dont even move, the only thing that works is the radio . im getting power to the starter but not to (or from ) the ign how ever it goes .
jason
Old Aug 19, 2004 | 04:16 PM
Maybe a dead battery. What do the headlights look like when you turn them on? Leave them on and try to start the car. What do the healights do, then?
Old Aug 19, 2004 | 08:10 PM
jadams94ta's Avatar
the headlight are fine when you try to start it .im getting 12.7 volt at the battery.
you know the little matel taps on your key mine are worn down to the plastic do you think that would make it not start with the vats
jason
Old Aug 19, 2004 | 10:42 PM
jason
Is the security light on? If you had a VATS problem, it would stay on. The security light does come on at the bulb test when you first turn the key ON, doesn't it? Then it should go out.
Old Aug 20, 2004 | 06:55 PM
jadams94ta's Avatar
no the guages dont work at all no lights of anything
Old Aug 20, 2004 | 07:17 PM
Sounds like it could be the ignition switch. If you happen to need to change it, there is a guide on my Tech Page. There are also starting and charging schematics so you can trace/troubleshoot any problems.
