Softest front springs for my LT1
Old Aug 13, 2004 | 12:23 PM
hozb817's Avatar
I am looking for a super soft spring to help with weight transfer. I'm concidering the Eibach Drag Launch Kit but I also am looking into making my own drag launch kit with super soft springs in the front, stiff springs in the back, and 2 airbags in between the springs. Any suggestions? Thanx for your imput!!
Old Aug 13, 2004 | 12:59 PM
Re: Softest front springs for my LT1
The stock rear springs are pretty decent for strip use. A friend of mine uses my old Formula stock rear springs in his 30th SS convertible, and he's currently running 8.6x@160+mph, 1.31 60-ft times. He was running the Eibach Drag Launch springs in the back, but wanted to switch back to a stock spring, and couldn't find his old ones. The car launches "just right":
http://cjcfo.fbody.com/members/injun...B/IMG_0710.jpg
If you do use airbags, you just want the one in the passenger side spring, to resist the torque reaction. The alternative would be a super stiff rear sway bar, like th eone Spohn sells. The car above uses a Wolfe bar.
Old Aug 13, 2004 | 01:03 PM
hozb817's Avatar
What about soft front springs? Thats what I am really looking for, Eibach, BMR, QA1, I just don't know which ones are the softest
Old Aug 13, 2004 | 01:31 PM
Somnambulist's Avatar
V6 springs
Old Aug 13, 2004 | 01:33 PM
hozb817's Avatar
Stock V6 springs or after market V6 springs?
Old Aug 13, 2004 | 04:03 PM
kgkern01's Avatar
Stock V6 springs will be softer than aftermarket. Most people want stiffer springs, so the aftermarket is basically all stiffer than stock.
Old Aug 13, 2004 | 04:12 PM
hozb817's Avatar
will I launch better at the track??
Old Aug 13, 2004 | 06:22 PM
with something like the drag launch kit from eibach, yea...
its all about the weight transfer to the rear on a launch...
ModdedNerd
Dec 25, 2014 05:51 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
