Opti Spark test?
Old Aug 16, 2004 | 04:25 PM
jpizzzle's Avatar
Opti Spark test?
Is there an easy way to tell if your opti spark is goin bad? i believe mine is, if you read my previous post about how my car chugs youll know why i am being lead to this conclusion... so if there is an easy way to tell if your opti spark is going please let me know...
Jon
Old Aug 16, 2004 | 04:43 PM
Re: Opti Spark test?
What year is your car? All LT1's are not the same. All years will set a trouble code in the PCM for problems with the optical section. None of them incorporate any direct checks on the high voltage function. But the OBD-II's will detect misfires by cylinder, and that might point you to the Opti if they are "random".
Shoebox also has a procedure on his Tech Pages website for verifying the optical signals.
http://shbox.com/1/4th_gen_tech2.html#opti_test
If you haven't used Shoebox's website before, bookmark it, because it is one of the best resources available on the 'net.
Old Aug 16, 2004 | 05:17 PM
jpizzzle's Avatar
i have a 95 m6 z28...if that makes any difference, and you may be able to determine my problem Injuneer, i have been having major chuggin problems ever since i had new plugs and wires installed. at about 1/4 throttle in any gear except first, the car chugs as if it is get gas and not getting gas/ sparking and not sparking... i was told this could be a possible misfire, arching and a few other things, any ideas as to what id wrong with my car? everyone put your heads together!
Jon
Old Aug 16, 2004 | 06:45 PM
If it started after the work, I would be checking over what was done. May be some plug wires mixed up.
Old Aug 16, 2004 | 07:54 PM
ABA383's Avatar
I agree with Shoebox..If it was OK before, then what's going on now.?..My car acted similarly and it was a burned plug wire. It was highly noticable lugging along in overdrive. Re-check all routings and firing order. Also make sure that the ends are completely snapped onto the plugs and into the opti. If you crimped your own, then re-check the opti ends where you crimped 'em...Good luck...
--Alan
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
