Anyone have the zz-x cam?
Old Aug 12, 2004 | 11:00 PM
jgonzales's Avatar
I'm about to start building a motor for my trans am. I was thinking about going with the ZZ-X cam from TPIS. Just wondering if anyone is using this cam. What kind of setup do you have and what kind of HP is it making?
Old Aug 13, 2004 | 06:29 AM
TQdrivenws6's Avatar
Re: Anyone have the zz-x cam?
I know of a 383, and a 402 with it. The 383, no idea on power. The 402 made 570/600 on the engine dyno, but keep in mind that was one hell of a motor.
Old Aug 16, 2004 | 04:13 PM
jgonzales's Avatar
that's pretty awesome. apparently, it's not a very popular cam... anyone have anything similar to it?
Old Aug 16, 2004 | 04:55 PM
Fastbird93's Avatar
What are the specs on it?
Old Aug 16, 2004 | 04:59 PM
239/239 .595/.595 112lsa I believe.
Old Aug 16, 2004 | 08:11 PM
96capricemgr's Avatar
Most smallblock heads are weak on the exhaust flow hence the almost universal intake/exhaust duration split, that cam may work well but for it to be ideal the heads will have to flow just right, in most cases you will be better off with more exhaust duration than intake. Besides that TPIS last I checked asked a rediculous price for cams and you could easily get a custom grind of similar or better specs for less money. If using stock heads the single pattern will be less than wonderful and if using ported heads and looking to make serious power talk to the porter about a recommendation. Also I see little chance of that passing the missfire test in OBD2.
Old Aug 18, 2004 | 06:21 PM
jgonzales's Avatar
i thought the lift was .558/.558 ??? and yes, they are outrageous with their pricing - somewhere around $400 i think. wasn't planning on using stock heads, wanted to go with AFR's, but i may have to just get mine ported. so this would be too much for the stock heads?
Old Aug 18, 2004 | 07:23 PM
ScreamnChicken's Avatar
That 383 that TQdrivenWS6 was talking about made 420 at the wheels. I believe it has CNC'ed track 1's for heads. He was getting some really bad valve float though, so he could only take it up to about 6200, and it was built to rev to around 7k.
Old Aug 18, 2004 | 07:27 PM
That is for the ZZ 9X
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
