Not passing smog- Here are the codes... help please!
Old Aug 16, 2004 | 03:41 AM
sswin24's Avatar
Hi,
I am in CA. I know my car will not currently pass smog. Currently its not registered or insured. My buddy hooked up his labtop and used his OBDII software to check my car out.
One code is P0430- TWC system low effiency Bank 2 (i beleive this means my 2nd cat is bad?)
also the software states that-
02 sensor monitoring system is incomplete and
EGR monitoring system is incomplete
Does anyone know how i can easily make these systems be complete? without driving around for hundreds of miles?
any help would be great. Car is 96 WS6 TA w/ 6speed. I have deprogrammed and capped my cutout for the test.
Old Aug 16, 2004 | 03:52 AM
ZeeDub's Avatar
Re: Not passing smog- Here are the codes... help please!
i dont know a whole lot about these cars, but usually that all means your O2 sensor is bad, and maybe even your EGR valve as well... did the car have a check engine light? or how did you get those codes? heres my advice........ if there is a check engine light, fixt it... no doubt... but if its smog thats pissing in your cheerios... just get a friend in the business..... he will know what to do ;-) how you think all these guys get away with SCs, and cams and heads, and X pipes.......... take a long break and think about it....
Old Aug 16, 2004 | 11:27 AM
P0430 = Three Way Catalytic Converter (TWC) system low efficiency Bank 2
You have two cats, one on each "bank" of the engine. Bank 2 is the cylinders on the passenger side. The code means the after-cat sensor on the passenger side is indicating that the cataytic convertor is not performing at required efficiency. Could be a worn out cat, could be a faulty after-cat O2 sensor?
Do you have cats? Do you have O2 sims? Have you deleted the EGR system? Has the PCM been reprogrammed?
Old Aug 16, 2004 | 01:36 PM
sswin24's Avatar
the SES light is on. I had the Hypertech programmer but i went back to stock and still the SES light comes on. I have cats and don't have o2 sims. I don't beleive i have deleted the EGR system? don't know what that means, or how its done. Is there anyway to make these test become complete without driving forever?
thanks
Old Aug 16, 2004 | 01:50 PM
jtk's Avatar
jtk
Repalce the CAT
Old Aug 16, 2004 | 01:52 PM
jtk's Avatar
jtk
oh yea, if you replace the CAT get one from the dealer only. dont try and stick a high flow cat on there
Old Aug 16, 2004 | 05:40 PM
sswin24's Avatar
why should i replace cat? i don't even know if thats the problem? I know this code comes up for a lot you so what have people done in the past?
Old Aug 16, 2004 | 06:01 PM
red96taA4's Avatar
my ses light is on for the same code..i dont have cats. the rear o2 sensor is just telling me that it knows something is up. i would go buy simms...but the light doesnt really bother me...it gives the dash a lil character,makes it a lil unique... i see alot of trans am's around here, but how many of them have their SES light on?? only me.
yea.....i dont mean that. i just cant afford simms. and im selling the car, so i dont care
Old Aug 16, 2004 | 06:59 PM
jtk's Avatar
jtk
a cat inificenty code most always means repalce the converter, unless you can do some further testing, just go ahead and repalce the coverter and while your there repalce the O2s.
there is a special way to drive a vehicle to make the monitors run, but its usualy a waste of time trying.
Old Aug 16, 2004 | 10:27 PM
OK.... before you assume the Mr. Goodwrench approach of randomly replacing parts until you find the one that fixes it , and dump big $$$$ for a factory convertor, try this.... swap the after-cat O2 sensors side-to-side. If the problem follows the sensor (switches to the other bank) its confirmed as a sensor problem. If the problem stays on the same bank, it EITHER a wiring problem or a convertor problem. Cost of making this check = "0".
I also don't agree that you need to stick to factory sourced cats.... I've had excellent luck with CarSound high flow cats.... those, along with some good tuning allowed my 230/242 solid roller 381 pass NJ rolling emissions. And they cost a lot less than the dealer is going to charge you.
Old Aug 17, 2004 | 03:16 AM
ZeeDub's Avatar
ive talked with a pro muffler guy, and he said there is no such thing as a "high performance" cat... they make good cats at a high flow rate, but anything costing you a bundle with some name on it is just a waste of money according to him. i listened, and switched to his cats..... cheap... efficient... and you can definately tell the difference!
David Dempsey
Mar 12, 2016 12:42 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
4586
Sep 6, 2015 03:10 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
Cam's maro
Aug 11, 2015 07:45 AM
