HP gains from P&P Stock Heads
Old Aug 13, 2004 | 01:17 AM
9T4Z28's Avatar
Question HP gains from P&P Stock Heads
How much is to be gained on Port and Polishing stock heads, on a stock setup? i dunt have the money to buy new heads anytime soon, so i was thinking about this, i doubt there is much, but i wanna be sure, ya kno. Is it a waste of money to get it done by a shop or is it better to do a home version? Thanks guys im kinda a newbie to these things.
Any info is greatfully appreciated.
Dan
Old Aug 13, 2004 | 01:29 AM
Mindgame's Avatar
Re: HP gains from P&P Stock Heads
Ok to want to learn, but cylinder heads are the heart of an engine. It will make or break the powerband so I personally recommend against porting your own heads unless you can get with an experienced porter. Then watch and learn.
If you want to do it on your own, follow the book I referenced in the other thread, get a junk head from a local builder (they usually have some around) and experiment. Keep in mind that good porting is not just about flowing lots of air. It's about creating the highest efficiency and making sure the fuel doesn't wet out the combustion chamber. The seat, venturi and throat area are very important. Every little change makes a big change in performance, so this is sensitive. I've heard porters talk about changing the throat diameter .010" the wrong way and losing 30hp (race engines).
Good luck.
-Mindgame
Old Aug 13, 2004 | 01:30 AM
9T4Z28's Avatar
thank u once again
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
