Changed my LT1's plugs today, one came out super clean?????
Old Aug 15, 2004 | 01:23 AM
BlackLT1_TX's Avatar
Well, got around to doing the plugs, put in some NGK TR55's.
I got a 1/2inch 5/8 spark plug socket and cut it shorter, worked great on number 8. The rest wernt that bad, number 2 sucked, but about 10 mins and I got it out and in. All in all took about 1.5 hours, and thats with manifolds, all accesorys, and on jackstands. Ended up doing most from underneath.
My question, however, is this. All of the plugs came out with what looked like some carbon build up around the circle that goes around the platinum that is exposed to the cylnder. All except for number 7 which was clean. The car does seem to run much better, and I was getting a high rpm stumble. Do you think this could mean that the number 7 wasnt firing, or is it not getting fuel or what?
Thanks,
James
Cliff notes: pulled plugs, all had carbon except number 7 which was clean, what does that mean?
Old Aug 15, 2004 | 07:45 AM
Re: Changed my LT1's plugs today, one came out super clean?????
If it did not have gas on it, could be that you have a coolant leak into the cylinder. You might want to put some miles on the new plugs and compare that one to another, again.
Old Aug 15, 2004 | 01:37 PM
Wouldnt I be getting some signs of coolant, like white smoke or ring wear causing blue smoke?
Also, I am guessing that the only way coolant could leak into an LT1 would be through the head gaskets since the intake manifold is dry.
Thanks,
James
Old Aug 15, 2004 | 03:16 PM
FastZinTennessee's Avatar
I agree........ When I had a blown head gasket, the cleanest combustion chamber was on the blown one.
Do what Shoebox said, and also keep an eye on the coolant level.
Old Aug 15, 2004 | 04:14 PM
Did you notice any white smoke? My car stays rather cool, although I have noticed that when the temp rises high, it has decided to keep getting hotter.
Old Aug 15, 2004 | 04:50 PM
RamAir95TA's Avatar
Like Rob mentioned, unusually clean internal parts are a sign of coolant steam-cleaning.
Old Aug 15, 2004 | 05:53 PM
I did notice white smoke. You might want to change your oil and see if it looks funky. Drain it into a pan, let it sit and see if anything separates. Since coolant and oil don't mix, you'll end up with splotchy looking oil in the pan if you have a blown headgasket.
Old Aug 15, 2004 | 05:57 PM
kingman109's Avatar
easiest way - funnel it into a soda bottle and let sit overnight- then look at bottom of bottle in morning
Old Aug 15, 2004 | 06:48 PM
pearlpurple's Avatar
Thanks,
James
When I blew my head gasket no signs of white smoke. One day coolant low light comes on, I added some, next day comes on again,, still no white smoke,, and no other obvious signs. I perform a cooling system pressure test and voila,, a slow leak. Once I did that I filled one cyclinder full of coolant, the engine hydrolocks,, once I got it going lots of white sweet smelling smoke.
If I were you I would check my oil very carefully, and perform a cooling system pressure test before doing any further serious driving as you will be changing bottom end bearings too if you are not careful.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
30thZ4C
Dec 26, 2014 05:09 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
StngStlkr
Sep 6, 2002 05:47 PM
