Ignition switch!!!
Old Aug 15, 2004 | 11:17 AM
crAzy95z28's Avatar
Ignition switch!!!
ok well i have a feeling my Ignition switch is going out... the symptom im getting this time is when turning the car on then off the key wont go all the way back to unlock the key from comming out, it gets stuck....
So is that the problem or is my Cylinder going out?
please let me know ASAP specially shoebox if you read this...
thanks
Randy
Old Aug 15, 2004 | 12:38 PM
med_reject's Avatar
Re: Ignition switch!!!
the problem is the adjustment of your park-lock cable http://shbox.com/trans/park_lock.html.
Unlock the clamp and pull the cable backwards (towards the back of the car) and then relock it. Then try rotating between on, run, crank, off etc. and see if there is any resistance.
This cable will not let you take out the key while you are in gear but if its adjusted incorrectly, it can be hard to take the key out when you are in park, or even to start the car.
Old Aug 15, 2004 | 12:44 PM
crAzy95z28's Avatar
good deal...ill try that as soon as my car gets back from the beach!
Randy
Henson071
Sep 18, 2015 04:01 PM
4586
Aug 18, 2015 07:08 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
Bails098
Aug 17, 2015 05:15 PM
Slayer
Aug 17, 2015 03:55 PM
