Is there any way to install the timing cover without dropping the oil pan?
Old Aug 15, 2004 | 07:11 PM
Valkyn71's Avatar
I've been trying for the last 2 hours to get the f'ing timing cover on, but it keeps pushing one side of the pan gasket in behind.
And i would like this opportunity to say whoever designed the timing cover and coolant crossover tube should have to travel around the country actually installing these stupid pieces of **** for all eternity.
Old Aug 15, 2004 | 07:25 PM
Formula_one's Avatar
Re: Is there any way to install the timing cover without dropping the oil pan?
Gotta drop the pan...
Old Aug 15, 2004 | 07:31 PM
93ZM6Tally's Avatar
Yep. Front of the pan has to be lowered enough to to fit the gasket over the bottom of the timing cover, or it will leak for sure if you try a "shortcut".
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
