Loss of High RPM power/stops pulling
Old Aug 15, 2004 | 06:20 PM
kgkern01's Avatar
My car has been doing this for a while now. When I get around 5k RPMs in WOT, it stops accelerating and it takes it forever to rev higher once it does this. It will also do this when shifting into the next gear, as soon as you shift, it keeps non-accelerating. If you part-throttle, it will rev on up to redline. I had it scanned once and afterwards had thought that it may have been the tear I found in the intake elbow. Well put on another intake elbow, same problem. What could be going on? Its not missing at all.
Here's the scan results:
5425 RPM, 45 MPH
MAP = 3.72
Throttle Sensor = 4.52, Throttle Angle = 99%
Left O2 = 796, Right O2 = 798
Left Injector Cycle = 11.3, Right Injector Cycle = 11.0
MAF = 153
CCP Duty 64.3%
Idle Air = 66 steps, Learned Idle = 21 steps
EGR = 0%
Spark Advance = 39*
Knock = 0%, Knock Sensor = 20
Closed Loop
Old Aug 16, 2004 | 10:00 AM
kgkern01's Avatar
Re: Loss of High RPM power/stops pulling
No one has any ideas as to what this could possibly be?
Old Aug 16, 2004 | 11:41 AM
Jerm982's Avatar
Fuel filter perhaps? Mine was doing the same type of thing, though it would completely cut out around 4.5k - 5k and would the backfire, turned out it was a bad coil.
Old Aug 16, 2004 | 12:39 PM
kgkern01's Avatar
I'm getting ready to change the oil, I'll go ahead and try the fuel filter and make sure the coil connections are clean also.
Old Aug 17, 2004 | 01:17 AM
kgkern01's Avatar
Figured it out...finally!! The rubber 90" elbow that I was using from the cone air filter to the MAF in my homeade CAI must have been collapsing upon itself at the high RPMs in WOT. I put the stock airbox back on, and it pulled fine up to redline. I wonder if this had helped in contributing to the tear in my 1LE elbow .
I fixed the problem by using a 3" aluminumized exhaust turndown for the bend. It now really pulls harder than it had before. This will be polished tomorrow.
Cam's maro
Mar 24, 2015 08:09 PM
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
