383 Questions, please advise...
Old Aug 15, 2004 | 11:57 AM
texasTA's Avatar
Well, I was going to do a heads/cam swap on my 94 LT1 Trans Am. Since then, I have got this crazy idea that I am going to go with a stroker + heads/cam
Well, I have been doing some research, but still have some unanswered quesitons.
Here is a quick list of my mods:
3.73 gears
Fully built A4 with a SS3600 Yank stall
Hooker Longtubes + 3inch True Duals
K&N FIPK
Well, I have a set of unmolested LT4 heads and intake manifold that I was going to have ported for my 350 bottom end.
My first question is, Can a stock set of LT4 heads be ported/worked over enough to support a 383 bottom end?
I also have a 233/239 .569/.577 111lsa Combinaiton Motorsports cam in my room that was going to go into my 350 bottom end.
My next question is, Will this cam be sufficient for a 383? If not, then what cam would you suggest with a LT4 ported top end and my other mods?
Lastly, How do strokers do with automatic transmissions? is this going to be a problem area for me?
Thanks guys and I am sure I will have a ton more questions regarding this.
Old Aug 15, 2004 | 12:05 PM
smokindastangs's Avatar
Re: 383 Questions, please advise...
The heads would work once opened up, in my opinion that cam would be ok....there might be better options out there but if your are trying to save money it would work. And I really don't know for sure about an A4 stroker, but I have never heard of anything that said it won't work. Hope this helps a little.
Old Aug 15, 2004 | 02:01 PM
texasTA's Avatar
SO would the ideal cam to go with in this setup, be a custom grind? My little brother has a 95 Formie that the 233/239 cam could go into. He has already offered to buy me another different grind cam and take the 233/239.
Old Aug 15, 2004 | 03:47 PM
RamAir95TA's Avatar
Depends on what the heads flow. Once the heads are done, it would be best to send the flow sheet to an engine designer/builder, and they will recommend a cam profile designed to meet your goals.
Old Aug 15, 2004 | 04:16 PM
SS MPSTR's Avatar
Get your LT4's ported and have a cam matched for the application. The LT4's will work great on a 383
Old Aug 16, 2004 | 09:21 AM
texasTA's Avatar
Cool, Well Jordon Musser is going to go all out on these heads/intake.
So who would you guys recommend to do a custom cam? Do you normally go with a performance shop (Combination Motorsports), or an individual like Joe Overton?
And I just found a LT1 block (4 bolt mains) from a 96 Vette I am going to purchase for the build up.
Old Aug 16, 2004 | 10:28 AM
Formula03's Avatar
As far as your transmission goes, if its built it shouldnt have a problem at all.
Old Aug 16, 2004 | 11:25 AM
texasTA's Avatar
It was definately given a "race rebuild" but I don't know just how good he did. Let's say that the tranny I have now goes out after 6 months (knocks on wood), would it be better with this much horsepower/torque to rebuild the 4L60-E again or is it time to go to like a TH-350/400?
Old Aug 16, 2004 | 03:18 PM
Formula03's Avatar
A properly built 4L60-E will handle it so, if it was me I would have it rebuilt. Especially if this will see much street duty or if money isnt an issue go Turbo 400 with a gear venders.
Old Aug 16, 2004 | 08:25 PM
texasTA's Avatar
This car will definately be a street/strip car. I don't believe in building them to sit in the garage.
Just any ol turbo 400 would bolt up?
D1SC383LT4
Jan 1, 2016 01:56 PM
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
