Could have some problems...
Old Aug 15, 2004 | 01:09 AM
a mean 94z's Avatar
A couple of weeks ago I started my car and noticed that the low coolant light was on. So I checked my coolant it was low, so I filled it back up. Well that happened once more then I haven't seen the light since....and coolant levels look fine.
When I was changing my oil I notice coolant on the crank hub, bottom of the water pump, opti......so I'm not sure if I have a bad radiator line or if the water pump is ****ting on me.
Anyway I posted some pics and maybe someone can help me............thanks.
Posted this over on LS1tech too, but I'll probably get more responses here...
Old Aug 15, 2004 | 07:47 AM
Re: Could have some problems...
Check the weep hole on the bottom of the water pump as soon as you come in from a drive (while there is still pressure in the system).
MustangEater82
Dec 30, 2005 07:40 AM
Highlander
Sep 15, 2004 08:42 PM
MustangEater82
Sep 30, 2003 12:09 AM
frmula1
Apr 30, 2003 02:07 PM
