Well, looks like that clean spark plug means head gasket, NEED BIG HELP!
Old Aug 15, 2004 | 11:43 PM
BlackLT1_TX's Avatar
Like I said in an earlier post, all my plugs looked the same except for number 7, which was clean. Well, I wrote it off as not firing, but I think you guys were right, I think I have a blown head gasket.
I checked my coolant tonight (which should be full) and the over flow is empty and I cant even feel coolant with my finger in the radiator.
So, I am going to get it presure tested tomorrow. If it ends up being a h/g, what are my options.
I know I will need to pull the accesorys, intake manifold, headers and heads, but is that it?
Also, are there any things I can do for cheap to help the car out performance wise while I have it all apart? I have heard of some using Impala h/g's.
I will be doing all this work my self btw, so is it easier to drop the whole thing out the bottom, or bust knuckles from up top?
-James
Old Aug 16, 2004 | 12:44 PM
Re: Well, looks like that clean spark plug means head gasket, NEED BIG HELP!
ttt
Old Aug 16, 2004 | 12:45 PM
ScreamnChicken's Avatar
Just go in from the top. Yes, you can get the impy head gaskets which are good for a few tenths of a point in compression. If you've got some disposable income, now would be a great time to do heads and cam...
Old Aug 16, 2004 | 02:10 PM
ZDriver96's Avatar
Bust knuckles from the top.. even though when u have the assembly out its so much easier to do the heads, its still a pain in the *** to hook all the connections, brake lines, and all the other crap back up..
Basically remove your alternator, intake manifold and headers.... All that takes a whole afternoon or so.. mainly the headers take the longest. then your heads.
If number 7 is steamed clean.. no black or brown on it then yeah very very likely u have a h/g leak.
Old Aug 16, 2004 | 03:02 PM
crAzy95z28's Avatar
you can get your heads surfaced, so they willbe super clean and smooth when you put them back on....or just go ahead and get heads and cam package....and some RR 1.6's springs, and some pushrods...
Randy
Old Aug 16, 2004 | 04:26 PM
ZDriver96's Avatar
more info- Hey its more of a clunk not a squeek. and it when i brake it doesnt hold the clunk... its like an initial hit clunk and thats it.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
nophix
Nov 30, 2014 10:26 PM
