does this sound bad to u?
Old Aug 16, 2004 | 05:22 PM
ARTIC_Z's Avatar
Angry does this sound bad to u?
ok car misses when cold and stops after it warms up. so i took it in for someone to just look at real quick. and he said that he thinks that the plug is blow open or the tip has broke off and is missing when cold then when the plug is warm it stops. now if the tip broke off is it just gona bounce around in there or what? im gona take out the plugs tonight and see. now if one has broke off can i take a pen magnite and stick it in there and see if i get anything? or will that not work.
Old Aug 16, 2004 | 05:25 PM
crAzy95z28's Avatar
Re: does this sound bad to u?
i think if a tip broke off, i think you would hear it in side the engine!!
does this only do at a cold start and then when warm the car drives fine?
Old Aug 16, 2004 | 05:44 PM
SiDeWaYZz28's Avatar
if a tip broke off it would have shot out your exhaust by now i think
Old Aug 17, 2004 | 01:22 PM
ARTIC_Z's Avatar
well accually it misses at idel when its warm or cold but only back fires when its cold. but normal driving it is fine.
Old Aug 17, 2004 | 01:25 PM
ARTIC_Z's Avatar
so should i just change all the plugs and wires and see if its any better.
Old Aug 17, 2004 | 01:42 PM
LWillmann's Avatar
a plug and wire change is a good idea, at least the plugs.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
DetroitZ28
Feb 13, 2015 07:33 AM
mattszm6
Dec 14, 2014 07:09 AM
