Would a leaking/blown head gasket make the car undrivable?
Old Aug 16, 2004 | 01:13 AM
BlackLT1_TX's Avatar
I am suspecting a head gasket problem, but the car still runs decent. If you search my name you can see why I suspect the head gasket.
So did your cars still operate somewhat normally?
Old Aug 16, 2004 | 01:48 AM
1982z28with18s's Avatar
Re: Would a leaking/blown head gasket make the car undrivable?
Yep it still runs, just not the best. Hell it still ran a 12.0 with a bad blown header gasket.
Old Aug 16, 2004 | 02:18 AM
I am talking about head gaskets, not header, which were you refering to?
Old Aug 16, 2004 | 02:23 AM
Sorry can't read, I was referring to the header gasket.
Old Aug 16, 2004 | 04:50 PM
ttt
Old Aug 16, 2004 | 04:56 PM
Valkyn71's Avatar
Its not really going to hurt anything too terribly, as long as you keep the coolant full. But i wouldnt drive it any longer than i had to.
Old Aug 17, 2004 | 08:43 PM
Tang's Avatar
It could blow your motor if you drive it too hard or too long. If the head gasket leaks coolant into the cylinder it could hydralic it and possible bend a rod or damage something else on the bottem end. A couple weeks ago we had to replace a motor in one of the cop cars because the intake gasket blew on the #1 cylinder causing coolant to go into the cylinder. The cop kept driving it all weekend and it was knocking pretty dang bad.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
