broken exhaust bolt
Old Aug 13, 2004 | 02:02 PM
Evilfrog's Avatar
broken exhaust bolt
st i'd like to just say. f@#$!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Second, even though they been soaking in wd40, my 12 year old exhaust bolt (Y-pipe to the manifold) broke when i went to drop the Y-Pipe....So... Now what do i do?
Old Aug 13, 2004 | 02:12 PM
Spinner's Avatar
Re: broken exhaust bolt
Buy headers
Old Aug 13, 2004 | 03:57 PM
Sevendustx1's Avatar
Ya either buy headesr or Take the manifold off and torch the bolts off be carefull try to be as acurate as possible. I had to do this on my friends 98 trans am worked out for me. I welded new regular hex bolts to the manifold after i cut the old ones. This way i didnt have to worry about holding them up top with a wrench i just tighten the nut from the bottom . The best way to get old bolts off is by heating them up red hot then spray them down with water.
Old Aug 13, 2004 | 04:46 PM
bdc95ta's Avatar
I had that happen took it to an exhaust shop and had them torch them. Now the studs are all angled wrong, the y-pipe will not come off and some of the tips are striped from me trying to get them off. So from my experiance I'd say f@$( it and get some headers and a custom y-pipe.
-b
Old Aug 13, 2004 | 04:50 PM
mourningyou's Avatar
bah, the quick ghetto fix is to go buy a small c-clamp, and get it as tight as humanly possible. check it every couple of weeks since heat and vibration will cause it to loosen over time. i used this in my z and have had no problems, 1 1/2 months so far. my brother has had one on his parisienne for like 5 months, no problems.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
95chwagon
Feb 28, 2015 12:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
