Lengthen MAF wires..????
Old Aug 14, 2004 | 02:52 AM
94 TA TT2S's Avatar
What would Be the best way to lengthen my maf wires??? I figure soldering them would be the best...What gauge wire.....??? Just finnished the LS1 setup and need to length the wires so Its not so close to the throttle cables and such.....
Old Aug 14, 2004 | 07:38 AM
97FormulaWS-6's Avatar
Re: Lengthen MAF wires..????
Well, you could lengthen them, or you can go to GM and get the WS-6 pigtail for 96/97 cars. It's a ~7"-8" extension for that harness.
If you're going to solder it, make sure your soldering skills are up to par, and heatshrink all the wires when you're done.
For lengthening most car harnesses I use 20 Ga wire for most sensors.
Old Aug 14, 2004 | 11:41 AM
94 TA TT2S's Avatar
Thanks Man I can do that.....So it would be plug and play??? I believe my Maff would be right where it would be on a WS6 car........For now it will work .....It is plugged in....But I want to Change the appearance...To make it look More Oem.....I Had to pull it from the bundle of wires..That goes along the Drivers side head so it would reach.....And it is pretty tight right now....
Does anyone have any pics I can look at???? Part Number????
Old Aug 14, 2004 | 06:14 PM
Yup, plug N Play... I've got one sitting on my shelf, I swapped it out with a different one now that I'm using a MAF from a Z06 Vette.
Old Aug 15, 2004 | 10:59 AM
94 TA TT2S's Avatar
Would it happen to have a part Number on it????
Old Aug 15, 2004 | 03:16 PM
12529241
Old Aug 16, 2004 | 11:04 PM
94 TA TT2S's Avatar
wanna sell???
Old Aug 17, 2004 | 06:28 AM
Sorry, nope... I'm keeping all the original parts to my car, incase in 20 years when there are only 100 left, I can return it to almost stock. :P
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
