Clunking noise from engine bay.
Old Aug 14, 2004 | 04:46 PM
Jon in SD 97Z's Avatar
Ugh...I'm getting an odd thumping/clunking noise at all RPM's. It used to come on sometimes when I turned on the AC but would dissapear when I'd raise RPM's above idle. Now it's there even with out the extra draw of the AC. Right when the clunking starts I'll notice the alternator charge (Voltage gauge) will drop below 10v, again usually remedied by a blip of the throttle. Any ideas? I left the car a few miles from the apartment because I didn't want to drive it in risk of further damaging something.
Old Aug 14, 2004 | 05:28 PM
Heatmaker's Avatar
Advanced Member
Re: Clunking noise from engine bay.
Since your mentioning items on your Pulley system.. it's probably belt, or pulley related.
Old Aug 14, 2004 | 05:49 PM
Yeah, after closer inspection it looks like the hub/harmonic balancer is loose/shaking. I'm going to rent a puller tomorrow and R&R it and see if that fixes it.
Old Aug 14, 2004 | 09:34 PM
ledfootz28's Avatar
could be missing some of the bolts on the balancer,or your hub/balancer is misaligned or sliding off?
Old Aug 14, 2004 | 11:28 PM
the bolts are all there, and i havent touched the balancer since pulling the LT4 Hot Cam (~30k miles ago) I'll be going under the car tomorrow though...
Old Aug 14, 2004 | 11:59 PM
It's been a long time since I did the cam, does anyone have a link to a write up for the balancer?
Fatdog2
Feb 12, 2015 12:24 PM
ModdedNerd
Dec 18, 2014 10:52 PM
formula218
Dec 2, 2014 04:27 PM
squarehead
Nov 21, 2014 08:02 PM
kandied91z
Aug 4, 2002 02:53 AM
