Bad Sensor or Computer Error???
Old Aug 13, 2004 | 05:45 PM
95z115's Avatar
On my 1995 Z28, my low coolant warning light went on. I added coolant, it took about half the container, half a gallon (I think). The light still goes on and off sometimes. Is this a bad sensor, or do I just need to take it to the shop, plug it into the computer, and reset the coolant warning thing?
Old Aug 13, 2004 | 06:22 PM
Re: Bad Sensor or Computer Error???
The low coolant sensor is prone to problems. If you unplug it, there won't be any consequences other than the light will no longer work. It does not report anything to the computer, so no problem with that.
If you want to retain it's use, replace the sensor.
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
cmdeshon
Jan 4, 2015 11:15 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
